Old 05-05-2021, 01:25 PM   #1
KillerBomb24
KillerBomb24's Avatar
Drives: 2012 Camaro 1LS
Trunk alignment
Whenever I close my trunk, there is a small gap on the right side of the trunk between the fender. At an angle you can actually see the tail light cover. The left side looks aligned. I’m guessing I have to loosen up a bolt or 2 to get it to align properly. Any ideas?
KillerBomb24 is offline   Reply With Quote
Old 05-05-2021, 02:48 PM   #2
Wizard1183
Wizard1183's Avatar
Drives: ABM SS2/RS M6
Send a message via Yahoo to Wizard1183
Check the top right of trunk (when opened as it’d be on underside) on that side for a rubber stopper. See if it adjusts by turning it. I see one near the rear pass tail light (that white button; why the hell is it white?). See if that one adjusts.
Life is short, drive it like you stole it!
Wizard1183 is offline   Reply With Quote
Old 05-05-2021, 02:55 PM   #3
tartagliazl1
tartagliazl1's Avatar
Drives: 2013 zl1 vert
Looks like the rear end has been painted before. From the pictures it looks like it has to go down and back towards the rear window.
22% lower/ 2.5 upper/ 2” headers/ cat delete/ x-pipe/ 2 gallon x tank/ 100-3 pump/ fic 1300/ dsx aux kit/ 103mm throttle body/ RPM 5” intake/ meth kit/ prometh lid injection/FI interchiller/ 160* stat/ ngk-7/ msd wires/ elite catch can/ tsp cam/ Che trunnions/ ported supercharger/ 1/2” lid spacer/ brick mod/BMR toe and trailing arms/ 751hp 757 tq SAE @17.3lb on a loaded dyno.
tartagliazl1 is offline   Reply With Quote
Old 05-05-2021, 03:04 PM   #4
Wizard1183
Wizard1183's Avatar
Check the gap on the left side. Hard to see if gap is straight on the right. It looks like there’s almost no gap next to rear window. If that’s the case? Trunk needs to be adjusted (only if gap on left is not consistent). If it’s not consistent? It should have a large gap on left side by window and tight by the tail light on left side which means adjust it. But yea. Cars been wrecked or what? That’s not factory paint on the trunk deck and corner of qrtr panel
Old 05-05-2021, 07:15 PM   #5
Camaro2ss2010
Camaro2ss2010's Avatar
Drives: 2010 Camaro 2SSRS M6
Does it look like it is hitting the stoppers?
ECS supercharger, Texas speed stage 3 boosted cam, Johnson 2110 race style lifters, ported throttle body, long tube headers, aeromotive fuel pump, fic injectors, ATI super damper, Corsa Extreme exhaust, elite engineering catch can and many other things.
Camaro2ss2010 is offline   Reply With Quote
Old 05-06-2021, 11:06 AM   #6
SSEssence
Instagram: Sangstah
SSEssence's Avatar
Drives: 2019 Camaro 1LE
if you loosen the bolts on the trunk arms, you can easily readjust that gap. Also you can just adjust the height via the rubber stoppers.
2019 SS 1LE - "CaSSandra" 2014 SS - "AleSSandra - Sold" 94 Z28 - Sold
Follow the build https://www.camaro6.com/forums/showthread.php?t=612717
SSEssence is offline   Reply With Quote
Old 05-07-2021, 01:52 AM   #7
AlanRubin
Banned
Drives: 2010 LS
You can PLAINLY see the rubber stop is all the way down on that side, there is no more
adjustment, except to raise it. It needs worked at the hinge, and/or striker. Mine
had a very small gap, the striker was off center, and up too high. Fixed it...
AlanRubin is offline   Reply With Quote
Old 05-07-2021, 12:04 PM   #8
KillerBomb24
Yeah I tried the rubber stoppers but they didn't help. I guess I have to loosen the bolts on the left side and tighten them on the right to shift the trunk to the right.
Old 05-09-2021, 06:50 AM   #9
hudson773
Drives: 2014 camaro SS
that is one DIRTY camaro, you should be ashamed
hudson773 is offline   Reply With Quote
Old 05-09-2021, 09:06 AM   #10
Modernmusclecar
Modernmusclecar's Avatar
Drives: 2011 Camaro SS
Dont be afraid to use brute strentgh and twist the panel with your hands. They do that online.
EPS CUSTOM GRIND CAM....K@N CAI....VMAX PTB.....FRANKENSTEIN STAGE 2 HEADS ...1 7/8 STAINLESS POWER CATTED LONGTUBE HEADERS...CORSA XTREME 3 INCH CATBACK.....CIRCLE D 3800 Pro Series stall...391 gears.....Ported/modded GPI intake .Forgestar drag pack with Mickey Thompson ET street drag radials AGP PERFORMANCE DYNO TUNED. 463 WHP 428 FTLBS TORQUE.
Modernmusclecar is offline   Reply With Quote
Old 05-26-2021, 12:23 PM   #11
KillerBomb24
Figured it out. Loosen the 4 bolts attached to the bottom of the trunk and adjust the bar. Do some tests by closing the trunk. Just be carful not to make the trunk fall off your car into your rear windshield.
Old 05-26-2021, 12:24 PM   #12
KillerBomb24
Photo guide I made
Old 05-26-2021, 02:25 PM   #13
1JEWLDSSRS
1JEWLDSSRS's Avatar
Drives: 2011 SS-RS
Still looks a tad high on that corner. But much better.
