Old 05-08-2021, 03:00 AM   #1
oheynick
oheynick's Avatar
Drives: 2013 Chevy Camaro 2SS L99
Hennessey CAI Sound vs Others?
I have a 2013 SS and am wanting a clean looking cold air intake that will also sound good. I’ve read that rotofab, vararaam, and cai are all amazing but I’m not necessarily looking into an increased performance. Can anyone send a video clip of their Henessey cold air intake so I can hear how it sounds? I’ve heard it sounds good but just can’t find a video of it.
oheynick is offline   Reply With Quote
Old 05-08-2021, 03:42 AM   #2
Bo White
Bo White's Avatar
The Hennessey intake is metal without a heat shield. For the most part it would underperform compared to the vast majority of the other top brands like Vararam and RotoFab.
2015 2SS 1LE Clutch reservoir, Vararam DRX, ported TB, TSP 2" headers, MGW shifter, stage 4 cam and Wilkes 11° 65cc heads
Totalled:
2010 1SS Wilkes Performance/Eagle 416 shortblock, TSP custom valvetrain, PRC 260 heads, Edelbrock Pro Flo 102, th400 swap, 8" PTC 5500 stall= 535/435 at the wheels tuned Gen 3 Performance and Dyno 10.97 @ 124 full weight in 3100 DA CamaroFest X
Old 05-08-2021, 04:08 AM   #3
Avenging Orange
Avenging Orange's Avatar
They will all sound/perform similar.
https://youtu.be/9JD9it6SmB8
https://youtu.be/xmelTlEzI34
Old 05-08-2021, 05:44 AM   #4
102SS
waiting at the tree
102SS's Avatar
Drives: SIM 2010 2SS/RS A6
When I first got my car I bought a used K/N cheap and it was ok but have since bought a CAI.
It looks awesome and sounds good too.
It looks like it belongs under the hood on a modern muscle car.
2010 2SS/RS A6 Just a few bolt-ons and appearance doo dads
102SS is offline   Reply With Quote
Old 05-08-2021, 07:14 AM   #5
joshnmn
2&THEHIT
joshnmn's Avatar
Drives: 5th Gen Camaro; 5th Gen Ram 3500
This is the first time I’ve ever seen someone ask about the way a CAI sounds.
joshnmn is offline   Reply With Quote
Old 05-08-2021, 07:15 AM   #6
pyroguy
Keeper of “THE list”
pyroguy's Avatar
Drives: ABM #832
Bo knows.
My car had a Hennessey CAI on it when I bought it. Unfortunately the previous owner didn’t purchase the heat shield to go with it so the thing was actually a hot air intake because all it was doing was sucking in hot engine bay air. Even with purchasing the Hennessey heat shield it does a TERRIBLE job isolating the intake from the engine temps. There’s a giant hole where the intake tube slides into from the top of the heat shield that doesn’t seal up.
If you’re looking for the open air box look, go with Rotofab. Their intakes are top notch and look great. You’ll get better performance as a side effect as well.
Check out my build thread
Old 05-08-2021, 08:58 AM   #7
Modernmusclecar
Modernmusclecar's Avatar
Drives: 2011 Camaro SS
Ive had a K@N cai on my car for 8 years. It was my first mod. It has the chrome tube and looks and sounds great. This subject has been beaten to death. Youre not winning or losing a race because of your choice of intake Buy the one you want..you will be happier.
EPS CUSTOM GRIND CAM....K@N CAI....VMAX PTB.....FRANKENSTEIN STAGE 2 HEADS ...1 7/8 STAINLESS POWER CATTED LONGTUBE HEADERS...CORSA XTREME 3 INCH CATBACK.....CIRCLE D 3800 Pro Series stall...391 gears.....Ported/modded GPI intake .Forgestar drag pack with Mickey Thompson ET street drag radials AGP PERFORMANCE DYNO TUNED. 463 WHP 428 FTLBS TORQUE.
Modernmusclecar is offline   Reply With Quote
Old 05-08-2021, 09:01 AM   #8
oheynick
oheynick's Avatar
2 of my buddies drive 5.0s and you can hear it.. love the noise and want to out-do them lol
Old 05-08-2021, 09:18 AM   #9
LCPLPunk
USA-1
LCPLPunk's Avatar
Drives: 2010 Camaro SS L99
If you can hear the intake over your exhaust, you are doing it wrong.
"A Camaro in the garage is safe, but that's not what Camaros are built for..."
R2C CAI / Apex Scoop / VMAX Ported TB / Speed Engineering LTHs / X-pipe / GPI port/rod-mod intake manifold / Circle D 3200 278mm Converter / 3.91 gears / DynoSteve tuned / 1LE Shocks/Struts/Toe Links / ZL1 Rear Sway Bar / Z/28 Trailing arms / Prothane Radius Arm & Subframe Bushings / BMR UCA Bracket, Steering rack bushing / B&M Tranny Cooler / RX Catch Can / Jannetty Tranny Dipstick / 2012+ Heater Hose / 2013+ Rearview Mirror / Fuel rail flip / Drake shifter / Oil Cooler Delete
LCPLPunk is offline   Reply With Quote
Old 05-08-2021, 10:05 AM   #10
pyroguy
pyroguy's Avatar
Drives: ABM #832
I laugh, but he's right! I happened upon a Mustang the other night. He revved his engine at me real big so I opened my Noweeds diverters and "outdid" him.
Old 05-08-2021, 02:37 PM   #11
Tarendor
Tarendor's Avatar
Drives: 2012 camaro 2ss rs L99
*side note*
When I ran my k&n I thermal wrapped it (it helped a lot with iat)
2012 2SS/RS, L99, no cats/mufflers, Ported intake manifold, fuel rail upgrade, ID1050x injectors, Vmax throttle body, 25% UDP, GPI DOD delete, GPI SS3, GPI cnc heads, GPI – 5/16″ Hardened Pushrods, BTR trunion upgrade, BTR .660 springs, pcv revamp w/dual catch cans, Circle D 3800, full BMR suspension & bushings. ZL1 fuel pump, HPT programmed fpcm. JMS bap, Snow VC-50 methanol setup. custom 4gal methonal tank, vs7875 turbo, FMIC, precision 46mm WG, 50mm BOV, 3bar map, SJM line lock, Innovate SCG-1, Hurst shifter with tap shift mod, ×2 Holley 14" fans Diy E85, Diy auxiliary pump
Tarendor is offline   Reply With Quote
Old 05-08-2021, 05:02 PM   #12
1JEWLDSSRS
1JEWLDSSRS's Avatar
Drives: 2011 SS-RS
^^^^ This, I have the same intake on my Camaro for the last 10 years, and also it was my first mod, sounds good especially with the giant intake manifold I'm running and the LT's and cam. I bought it because I liked the way it looked because I do a lot of car shows and cruises. As stated, get what YOU want because it is your car. When I romp on mine, you can hear all the big air being sucked up into the manifold!! Pretty awesome!!
Old 05-08-2021, 05:27 PM   #13
joshnmn
2&THEHIT
joshnmn's Avatar
You want your car to suck harder than a mustang? Buy a Dodge...
Old 05-08-2021, 06:59 PM   #14
Batmanntexas
Batmanntexas's Avatar
Drives: 2012 Camaro SS (2SS)
745RWHP/634RWTQ on 93 @ 10psi
806/676 on E85 @ 10psi
Currently @15-16psi....
COTW 9/8/14
Batmanntexas is offline   Reply With Quote
cai, cold air intake, hennessey, sound clips
