Old 05-09-2021, 10:39 PM   #1
ZX1truth
ZX1truth's Avatar
Drives: 2010 2SS/RS
Blown out LS3 water pump rear plug
Has anyone here blown out their LSX/ LS3 water pump rear panel/plug????? I was making a hard pass tuning the Pro EFI computer today and this water pump rear plug blew out on my 427LSX TT motor.
LME built LSX427 w/t all Callies internals| AGP 65/65 TT | Holley Sniper Intake | Brodix BR3/LME custom ported | LME custom cam | Pro EFI 112 ECU | ID-1700x | NGK BR7EF | AGP's-Fore Triple Fuel pump | Monster LT1-S Triple | ZL1 3.23 diff, CF driveshaft, ZL1 axles | Hurst Line Lock | MGW Retro Short Throw | Pfadt solid subframe mounts | Prothane Motor Mounts | Revshift Poly Trans insert | Ground Control camber/caster plates | Accelerated Racing Solutions tuned|
God is too good! I don't deserve it, but I sure will accept it!!!
ZX1truth is offline   Reply With Quote
Old 05-10-2021, 09:26 PM   #2
ZX1truth
ZX1truth's Avatar
Drives: 2010 2SS/RS
Wow.......guess no one else has ever had this issue??? Anyone??? Well I am going to replace the old LS3 with a high performance PRW high volume water pump.
https://store.prw-usa.com/1434601-wa...ation-as-cast/
Old 05-11-2021, 09:33 AM   #3
Greenhornet2
Greenhornet2's Avatar
Drives: 2011 Camaro 2SS LS3 Whipple
I've seen freeze plugs blow out from a blown head gasket but never a water pump plug. If your not losing compression into your cooling system I'd assume the plug just wasn't sealed correctly.
Greenhornet2 is offline   Reply With Quote
Old 05-15-2021, 10:46 PM   #4
ZX1truth
ZX1truth's Avatar
Drives: 2010 2SS/RS
Thanx GH........ My LSX has screwed in freeze plugs. The WP was 11 years old and I am hoping that is why it blew. I am checking compression next.
Old 05-16-2021, 12:29 AM   #5
SSE 4 2SS
Boosted Moderator
SSE 4 2SS's Avatar
Drives: Bone Stock LS3
I’ve blown a radiator out, swelled it, from a leaking head gasket and lotsa boost... Gasket was leaking due to the boost....and some giggle gas... lol... Radiator never leaked a drop... I swapped it out for an aluminum aftermarket radiator...
I’m guessing you are aware there is a pressure sensor you can use for the coolant system with ProEfi... A sudden spike in pressure (Indicative of a sudden head gasket leak due to boost or combustion chamber pressures) will put you into limp mode or even kill the motor...
Old 05-18-2021, 02:33 PM   #6
stevieturbo
Drives: it changes
On my LS2 pump I have noticed the rear plug moving a little, but it's never actually come all the way out.
Given the diameter of it, even with say 15psi in the system, that's a lot of force acting on it as it's pretty large diameter
stevieturbo is offline   Reply With Quote
Old 06-17-2022, 09:07 PM   #7
SSyclone
SSyclone's Avatar
Drives: 2011 2SS Inferno Orange
I know I'm dragging up a year old post.
Yes I just did this two weeks ago. Is this just a fluke. My car is an 11, lsa conversion etc. I've never even seen a drop of coolant leakage. Then during a hard pass..... Her water broke.
Anyone else do this?
2011 Camaro SS
Buckets of money under hood!
SSyclone is offline   Reply With Quote
Old 06-18-2022, 12:51 PM   #8
caper
Drives: 2010 IOM 2ss/RS
pretty sure this happened to me as well, driving normally lol. lost all water within seconds. blew the whole pump apart is what the mechanic said lol.
Turbonetics running 8lbs boost at 700rwhp tuned by Hi Rev, installed by K&M w/cat-muffler delete, ACS splitter, Fesler GFX, MPD1 spoiler, Custom painted Rally stripes, Cordon CR1 wheels 275/315s, Hotchkiss comp sways and end links, Barton shifter
caper is offline   Reply With Quote
Old 07-13-2022, 12:08 PM   #9
Scott S
Scott S
I had it happen on a Silverado with a new GM pump from Rock Auto...
769HP/699 Torque LS3 heads ported and polished with BTR Spring kit & Trunion upgrade, LSA supercharger ported by DC Porting, 102MM throttle Body, 2.40 pulley upper pulley, Innovators West 10% Overdrive lower, BTR Stage 3 PDS Blower Cam, Mighty Mouse Catch Can, SMG Flex Fuel kit, SMG Aux Fuel System, FIC 1000 Injectors, MGW Flat Stick Shifter, RPM Stage Vll Transmission, McLeod RXT clutch, ARH 1 7/8 Headers, 3" X-pipe with Borla S-Type mufflers, ZL1 3:23 rear diff and Axles, 1LE suspension. Bmr Bushings in back. TUNING AND SPECIAL ALIGNMENT BY CARL@Twincitiesperformance
Scott S is offline   Reply With Quote
