Old 05-10-2021, 08:48 PM   #1
Kbell99
Drives: 2011 Camaro 2ss
Correct pushrod length?
When i checked for 0 lash, my pushrod length was 7.525 (7.5+ a half turn). I talked to the tech guy at Johnson, and he advised me to go to about .050 preload instead of the advertised .035, due to engine expansion. I ordered 7.575” pushrods from trend performance. When I put the rockers on none of them sat on the pedestal, but after i torqued them down they were fine, a little side to side just like they were supposed to. 1 of the rockers canted to the side a hair, its still on top of the valve, but not perfectly in line with the pedestal. I have to dyno this Friday 5/14, and am wondering if i should just bite the bullet and order a slightly smaller set.. any advice would be appreciated
Kbell99 is offline   Reply With Quote
Old 05-10-2021, 09:18 PM   #2
Clarkstar
Clarkstar's Avatar
Drives: 2013 1SS 1LE
Which lifters? Stock rockers?
2013 1le- Katech 416 short block, TSP custom grind cam, LOD intake, cnc heads by F.ED., Nick William's 102mm T.B., CORN fed, Pedders coilovers. Performance street alingnment by Justin at Lake Country Alignment and dyno tune by Late Model Throttle.
603 h.p. 495 ft lbs tq.
Clarkstar is offline   Reply With Quote
Old 05-10-2021, 10:31 PM   #3
Kbell99
I have johnson 2116LSR lifters and yeah kept stock rockers and went with the TSP trunnion upgrade.
Old 05-11-2021, 06:53 AM   #4
Clarkstar
Clarkstar's Avatar
Well, I measured every one and ordered the lengths I needed for .035 preload. I think I ended up with 6 different lengths total. Maybe overkill for a streetcar but I wanted it right...
Your probably ok with the length you have, and it should be quiet. If you want to be 100% sure you have to measure them all.
Old 05-11-2021, 07:10 AM   #5
Bildo
Bildo's Avatar
Drives: 2012 2SS/RS LS3
Absolute correct way to do it!
2012 2SS M6, ERL Superdeck 6 427, PRC 255 Heads, Procharger F1A w/ 3.85 pulley, 1300hp intercooler, Squash Dual 450lph, E85, ID1700, RXT Clutch, DSS 1pc driveshaft, GForce axles, Eaton Detroit Trutrac, a bunch of other crap I don't feel like typing.
Bildo is offline   Reply With Quote
Old 05-11-2021, 07:25 AM   #6
Kbell99
Okay, i dont have the tools to measure my final length, as i am doing this in a frickin apartment. But thats what i kinda figured the one rocker sitting slightly crooked is just a concern, i read that sometimes the rods are a hair longer or shorter so i think thats what I’ll chock it up to, and just pray when i start it that my valves dont falcon punch my pistons.
Old 05-11-2021, 09:33 AM   #7
Clarkstar
Clarkstar's Avatar
How did you get your length? You have an adjustable push rod? That's really all you need... I used a caliper to measure mine to be sure... but I think just going off the adjustable push rod will be good enough.
Old 05-11-2021, 02:14 PM   #8
zz430camaro
zz430camaro's Avatar
Drives: 2015 1LE
When i checked for 0 lash, my pushrod length was 7.525 (7.5+ a half turn). What does the 1/2 turn mean? Zero lash is when all play is taken up and no pre load. If 7.525 was truly zero lash then a 7.575 push rod will be just fine, that lifter has 0.100" plunger travel so it will be in the middle when cold and you have plenty of room on either side. Did you start it? Is it really noisy?
2015 1LE, TSP 225/236 113+3, VMAX Throttle Body, CAI with race scoop, GPI Ported Intake, Land Speed Stage 2 Heads, 1-7/8 headers, NPP exhaust, 25% Fluidampr, LT1-S Monster Clutch, 485 RWHP & 444 TQ
zz430camaro is offline   Reply With Quote
Old 05-11-2021, 06:03 PM   #9
1LEsteiny
1LEsteiny's Avatar
Drives: 2015 1le
Did you tighten them down when each cylinder was on base circle?
1LEsteiny is offline   Reply With Quote
Old 05-11-2021, 06:54 PM   #10
Kbell99
I just measured for length at 0 lash with the adjustable, then added my preload to that, is it a problem that the rocker isn’t perfectly square with the pedestal? It only took 3/4 after hand tight to get to torque value so it should be right, but the rocker is a little cattywompus
Old 05-11-2021, 08:15 PM   #11
Clarkstar
Clarkstar's Avatar
3/4 turn is fine...
I'd take that rocker off and make sure your on the base circle then try again
preload, pushrods, rocker arms
