Old 05-13-2021, 08:58 PM   #1
Kbell99
Drives: 2011 Camaro 2ss
Pickup tube seated but pump wont move
I have my oil pickup tube fully seated with the improved racing brace installed as well, however, i cant get my pump to move to the bolt holes, anyone been in a similar predicament. Ps i gotta have this back together in the am I have dyno day tomorrow. Name:  2CD166EC-35D0-4FB5-9A13-4F74F2A2D745.jpg
Kbell99 is offline   Reply With Quote
Old 05-13-2021, 10:26 PM   #2
gunchamp
gunchamp's Avatar
Drives: 15 Camaro SS
Maybe the pickup got slightly bent when you took it apart or put back together? If you have the pickup seated properly, i would draw it down with the bolts. Tube should bend very easy. Mine did
15 Camaro SS- GPI max top end, ESS Vortech V3 9psi, ID 1050s, ZL1 pump, JMS bap, Long tubes, Corsa extreme, Circle D pro 5C, 391 rear, DSS carbon drive shaft, poly cradle bushings, tuned by Ted Jannetty and much much more
gunchamp is offline   Reply With Quote
Old 05-13-2021, 10:56 PM   #3
WHAMMO
WHAMMO's Avatar
Drives: 13' 1LE
Happemo to me. You have to wiggle and try over m over until it works. GL
13' 1LE
Old setup: TSP 231-236/Tick 660/.105 PR, UDP, SW LT 2'' & HFC, stock NPP & H pipe, VR-DRX CAI, air scoop, Goertz1 manifold, 102mm BBK, 26" Toyo DRs, Forgestars R17x10 & F18x8, rear seat delete, remote Pat G tune Autocal, 7400 limiter, Spec Mini Twin. 91oct. 11.90@122.3, 0-60ft 2.0 / 11.99@123.6, 0-60ft 2.1 DA+819 ...519RWHP SAE
Solid roller SBE LS3, FED, LLSR, 91oct, 605rwhp N/A. Tuned by Pat G. Build by me.
WHAMMO is offline   Reply With Quote
Old 05-13-2021, 11:42 PM   #4
InFiD3ViL
InFiD3ViL's Avatar
Oh damn! Thats with the pickup bolted to the pump already?
Old 05-14-2021, 12:28 AM   #5
FasNuf
FasNuf's Avatar
Drives: 2014 Camaro ZL1
Not sure why your pickup tube seems to extend out, but it's a good idea to align your pump to the crankshaft. I aligned mine then torqued the mounting bolts, then I installed the tube using plenty of lube on the oring and pump.
FasNuf is offline   Reply With Quote
oil pump
