01-04-2010, 07:14 PM | #1 |
Drives: CGM 2SS/RS Join Date: Jul 2009
Got my pac line converter
Now can someone tell me what wires I connect too? Please dont just post the diagram that is all ready in the sticky I cant make heads or tails of it SO if someone can just tell me what color wires I solder into that would be great. Also for the amp turn on wire.
01-04-2010, 07:22 PM | #2 |
Do you have the Boston Acoustics system?
01-04-2010, 07:30 PM | #3 |
01-04-2010, 07:38 PM | #4 |
Wires From PAC-------------Wires Going Into BA Amp
Gray------------------------Dark Blue Gray w/ Black Stripe---------Tan White-----------------------Brown w/ White Stripe White w/ Black Stripe--------Brown Remote turn on--------------White Although this is probably a bad time to tell you this, the line converter is completely unnecessary when adding an amp to the BA system. If you simply splice a patch cable into the above wires as they come into the amp you will get a line level signal. The PAC is redundant - you are converting a signal that is already line level to line level. I know some folks that have used them and it sounds ok, but when I did my install (with a crappy scosche line converter) the volume level and sound quality sucked. I pulled the line converter out of the mix and just spliced direct into the signal to the amp and it sounded 100% better. Good luck! |
Similar Threads | ||||
So My SS is on the line this week Production process question? | mslone | Camaro Price | Ordering | Tracking | Dealers Discussions | 3 | 09-17-2009 02:43 PM |
How long does it take for a 2010 Camaro to go down the assembly line? | Menardgang | 5th Gen Camaro SS LS LT General Discussions | 27 | 09-10-2009 12:57 AM |
Fuel Line Size | JSOC_MQ1 | Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons | 0 | 08-10-2009 09:50 PM |
Looking for pics of Rally Yellow 2SS on assembly line | NewCamaroGuy | Camaro Photos | Spyshots | Video | Media Gallery | 7 | 08-05-2009 12:08 PM |
L99 owners please weigh in. | PQ | Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons | 130 | 07-11-2009 10:18 PM |
