![]() Drives: 2011 Camaro 2ss Join Date: Apr 2021
Oil pump
Has anyone ever messed with their pickup tube, causing it to become over extended? When trying to install my new melling HP pump, i have the pickup tube installed and seated, braced as well, but the assembly is about 1/2 inch away from the face of the block. It does not want to wiggle into place and only slightly moves under a ton of force, does anyone have any experience with this, i have to dyno this friday!!
#2 | |
![]() Drives: 2010 Camaro SS Join Date: Oct 2020
https://youtu.be/LMcajfO6fnM Also if you have time order you up one of these. The single bolt design on the pickup is garbage. This makes sure it does not come loose and that it is installed properly. https://www.summitracing.com/parts/i...-500?rrec=true Sent from my SM-F916U using Tapatalk |
#3 | |
That's really odd is the pan loosened? I did not remove my pan but I backed all the bolts out about 3/4 to make room to get the bolt out of the pickup.
| Tags |
| oil pump, trouble |
