Old 05-19-2021, 12:28 PM   #1
Att3mpt
Drives: Chevy Camaro 2015 2SS RS
1050x or 1300x
Hi I am recently going to go with Magnuson heartbeat supercharger with the following support mods
ZL1 FUEL PUMP COMPLETE
"JRE PROGRAMMED ZL1 FUEL PUMP CONTROL
MODULE"
ZR1 3 BAR MAP SENSOR
"Roto-fab HEART BEAT SUPER CHARGER
AIR INTAKE KIT"
TR7IX IRIDUM SPARK PLUG
ID-1050X 1260 CC @ 4 BAR GM SHORTY
JMS FUEL PUMP VOLTAGE BOOSTER
this is specifically for l99 camaro
I am not too knowledgable about the injectors but is it worth spending that extra $700 for a 1300x? Will I ever max out the 1050x for the 1300x to be worth it? I'm hoping for a end goal of around 700whp way down in the future when the car is no longer DD.
Thanks in advance
Att3mpt is offline   Reply With Quote
Old 05-19-2021, 12:38 PM   #2
larry_g
larry_g's Avatar
Drives: 2014 1SS/1LE
At that power level the 1050X are more than enough.
Old 05-19-2021, 12:40 PM   #3
Att3mpt
Thanks for your reply,
curious with proper tuning and everything what is the 1050x maxed out at?
Old 05-19-2021, 10:16 PM   #4
gunchamp
gunchamp's Avatar
Drives: 15 Camaro SS
1050s in my setup with room to move. 1300 if your running E and have goals of chasing big big power
15 Camaro SS- GPI max top end, ESS Vortech V3 9psi, ID 1050s, ZL1 pump, JMS bap, Long tubes, Corsa extreme, Circle D pro 5C, 391 rear, DSS carbon drive shaft, poly cradle bushings, tuned by Ted Jannetty and much much more
gunchamp is offline   Reply With Quote
Old 05-19-2021, 10:25 PM   #5
Vegas Bound
Drives: 2013 Sparkly Red One
I went 1300 for the room to grow and alcohol.
Vegas Bound is offline   Reply With Quote
Old 05-20-2021, 07:26 AM   #6
larry_g
larry_g's Avatar
Well I'm at 750 whp, running the 1050X on E85 at about 72 psi fuel rail pressure due to a boost referenced FPR on a return style system. My IDCs are in the 60's so I still have room to grow.
The thing about shooting for 700 and up is that you will run out of fuel pump before the 1050X becomes your limiting factor.
Old 05-20-2021, 09:22 AM   #7
Greenhornet2
Greenhornet2's Avatar
Drives: 2011 Camaro 2SS LS3 Whipple
You'll never make enough power with the Maggie to need bigger than 1050s. Over 700ishwhp on 93octane or running E85 you'll need to upgrade fuel pump first as noted above.
Greenhornet2 is offline   Reply With Quote
Old 05-20-2021, 12:48 PM   #8
eLeSthree
Drives: 2011 Camaro SS 6sp
Raise your hand if you've had to buy fuel injectors 3 times and are once again running out of fuel injector...
I can't find the hand emoticon, but this should do it.
2011 Camaro SS---SOLD
TMS Dart 427 FED M311s, ESS Tuning G4 Blower, DSX Triple FP Assembly, DSX FF, FIC1300, Mcleod RXT 1200HD, Edlebrock Pro Flo XT
1158whp 1017wtq.
2010 CTS-V A6 - "Stock" SOLD
630whp 658wtq
2024 F-150 RCSB 5.0 4x4
waiting for tunes...
eLeSthree is offline   Reply With Quote
Old 05-20-2021, 01:23 PM   #9
gunchamp
gunchamp's Avatar
HAHA!
Old 06-05-2021, 11:27 PM   #10
Rem0v3r
Drives: 2013 ss2 vert l99
Fuel injector connection sells 1700s for about 1250..
My fuel injector connection 1000s have worked great for years... do yourself a favor and buy the largest injector you can.. you will eventually need it.
Rem0v3r is offline   Reply With Quote
Old 06-06-2021, 03:40 AM   #11
Att3mpt
I heard 1700 is just an overkill probably 1300 ��
Old 06-07-2021, 04:40 PM   #12
BiggFoot
BiggFoot's Avatar
Drives: 2010 Camaro (M6) 1000+ HP SBE
Depends on your setup and where you may end up down the road. If there isnt that much difference in price then go big my friend. You may need the extra squirt down the line.
F-1X, Cog Drive, ATI Super Pulley/Sprag ~ 19 psi
Blower Cam
Brodix BP BR 3 Heads
Kooks LT Headers and full 3" exhaust
Fore Triple Pump Fuel System with ID 1700X Injectors - E85 conversion
DSS 9” Conversion (1400 hp axles, driveshaft, pumpkin) & Strange 3.70 gears
McLeod RXT Twin HD Clutch & Upgraded Slave
RPM Level VII
TR6060
BMR Drag Suspension Package w/Strange shocks
Carlyle 15" and M/T ET Street R radials
10.1 @ 143 mph 1/4 mile
BiggFoot is offline   Reply With Quote
Old 06-07-2021, 04:42 PM   #13
BiggFoot
BiggFoot's Avatar
Blower Cam
RPM Level VII
TR6060
1050x, 1300x, force induction, injector dynamics, magnuson heartbeat
