Old 05-19-2021, 11:30 PM   #1
L8brake1LE
Drives: 2015 Camaro 1LE
GM Performance ASA Cam 88958770- NIB $499!
PRICED TO SELL FAST!!! install instant horsepower in a weekend with this bad boy ASA cam!! Retails for $634 all day long.
In stock ready to ship immediately to your door!
Check out my other listings on eBay for the entire valve spring kit for this cam which makes it race ready with high quality parts from Comp cams!
Comp cams 26918TS tool steel valve spring kit compliments this cam very well vs cheap beehive springs
Genuine GM Performance Camshaft - guaranteed
Other listed are not GM so beware. This is in a GM original box and packaging 2021 stock.
Chevrolet Performance Parts Hydraulic Roller ASA Camshaft 88958770.
LS SERIES CAMSHAFTS
All LS camshafts are compatible with production-style LSX and C5R blocks, as well as all of our cylinder heads – although piston-to-valve clearance must be checked on some applications. We offer a broad range of production and racing-style camshafts that are factory-engineered to deliver maximum performance when paired with our high-flow cylinder heads. Save yourself the time and expense of going to an aftermarket camshaft supplier and build your LS engine with a genuine GM cam. We’ve also got the valvetrain components you need to finish the engine, including lightweight components designed for high-rpm performance.
ASA Camshaft
Duration @ .050" Lift( Deg): Intake: 226 / Exhaust: 236
Maximum Lift (in) W/ 1.7 Rocker: Intake: .525 / Exhaust: .525
Lobe Centerline ( deg): 110
Technical Notes: Cam requires valve spring P/N 12499224
“ASA” cam for off-highway use
L8brake1LE is offline   Reply With Quote
