Old 05-19-2021, 11:40 PM   #1
L8brake1LE
Drives: 2015 Camaro 1LE
Comp Cams Valve Spring kit 26918TS $425 NIB
This is sold out all over the internet!!
Nothing in tool steel is available from Comp Cams or any dealer.
This kit is on national backorder! Good luck finding one so grab yours now !
Posted in other selling platforms along with my GM ASA cam.
Brand new in the box ready to ship to your door!!
Prices to sell fast! these kits are very hard to find and on back order with Comp cams! Anything tool steel is hard to find right now.
Brand new in box and packaging ready to ship to your door!
Thanks for looking please ask questions before purchasing and do your research on this part number.
No returns accepted please do your research as this is a very popular kit and tool steel makes it even more robust for racing applications.
Competition Cams 26918TS-KIT LS Engine Beehive Valve Spring Kit. Condition is BRAND NEW
26918TS-KIT
LS Engine Beehive Valve Spring Kit; Incl. Beehive Valve Springs PN[26918-16]/Lightweight Tool Steel Retainers/7 deg. Steel Valve Locks/Valve Seals/Spring Seats;
Valve Spring
SPECIFICATIONS:
Camshaft Type: OEM
Coil Bind Height (in.): OEM
Inside Diameter: 0.660/0.885
Installed Height (in.): 1.8
Installed Pressure (lbs.): 125
Open Height (in.): 1.15
Open Pressure (lbs.): 367
Outside Diameter: 1.055/1.29
Position: N/A
Spring Rate (lbs./in.): 313
Spring Type: Single
FEATURES:
Contains Everything You Need
For more than 35 years, the COMP Cams(R) mission has never changed: to produce the highest-performing products possible, provide customers with superior service, and to lead the industry in technological development. While the COMP Performance Group(TM) has grown to multiple companies and hundreds of employees, we still retain the competitive spirit and desire to be the very best that has positioned COMP Cams(R) as the absolute leader in valve train components.
COMP Cams manufactures truly superior hydraulic and solid flat tappet, hyd and mechanical roller, and overhead camshafts for everything from OE replacement to full race, designed and manufactured using cutting-edge technology and the finest engineering in the industry. Whether your engine is naturally aspirated, or you run nitrous, or a supercharger or turbo, our cams make more horsepower than any other. Looking for that ultimate hard-hitting muscle car idle? Check out our aggressive new Thumpr Cams. Match our camshafts up with our competition-grade lifters, valve springs, timing sets, and other supporting components, and you'll experience the ultimate in race-winning reliability!
Shipping US only
No returns accepted
UPS ground to your door.
Please ask questions before buying or winning auction
Immediate payment is due at the end of sale please
Item Specifics
Brand COMP Cams
Part Number 26918TS-KIT
Part Type Valve Spring kit
L8brake1LE is offline   Reply With Quote
