Old 05-22-2021, 01:48 AM   #1
Lsguy
Drives: 2010 camaro
Compression Ratio help.
So I picked my motor up from the machine shop yesterday and the work done is great but I do have a problem. Its a gen 4 6.0 stroked to 408.
Bore 4.030
Stroke 6.125
Pistons wis k464x3
Dome 3.00
Heads stock ls3 duel 660 springs
CnC Deck 9.230
I was told with a 55mm gasket compression would be 11.1 from what I've read thats way to high for pump gas so what can I do without ordering some more $900 pistons. Its a Turbo car
Lsguy is offline   Reply With Quote
Old 05-22-2021, 02:22 AM   #2
ttshovel
ttshovel's Avatar
Drives: 12 camaro ss, 72 chevelle, 91camaro
Aside from ordering pistons your only real option is to go to e85. You can run a thicker gasket but thats asking a lot. The math works out to 11.04:1 with a ls9 headgasket(.059 thick) and assuming zero deck.
ttshovel is offline   Reply With Quote
Old 05-22-2021, 03:54 AM   #3
Lsguy
Drives: 2010 camaro
Question
The only problem with e85 is I live in knoxville tn and there's only 2 gas stations around here that has e85 and they're both 40 minutes from where I live on top of that it puts me out of doing any type of drag week or anything like that.
Old 05-22-2021, 04:20 AM   #4
Lsguy
Drives: 2010 camaro
Question
Would it be possible to get the CR down by swapping to a aftermarket head
Old 05-22-2021, 04:35 AM   #5
ttshovel
ttshovel's Avatar
You could get it down with an aftermarket head, but even so a .059 ls9 gasket with a 72cc chamber would net 10.59:1
They do have a .070 gasket that gets you 10.34:1 with a 72cc head.
Old 05-23-2021, 07:39 AM   #6
G8One2
Drives: 2014 Camaro 2SS
Static compression means nothing. Your cam and valve events dictate your effective compression. My last car (g8) had a 6.0L , .035" gaskets and 11.7 compression that ran just fine with no knock on 93 octane. Your best bet would be to go with the shop who built it, recommendation.
G8One2 is offline   Reply With Quote
Old 05-23-2021, 09:22 AM   #7
Rem0v3r
Drives: 2013 ss2 vert l99
I second going to e85.. youre a big cube boosted ls car.. at some point you're going to have to transition to E if you want to make good power... go buy a bunch of gas cans and fill up once a month.. at any rate, going to get gas is a good excuse to drive your car :-)
Rem0v3r is offline   Reply With Quote
Old 05-23-2021, 10:52 AM   #8
ttshovel
ttshovel's Avatar
Hes not gonna get dynamic compression down enough with a cam being boosted. You must have missed that last line of his first post
Old 05-23-2021, 11:54 AM   #9
gunchamp
gunchamp's Avatar
Drives: 15 Camaro SS
Bore 4.030
Stroke 6.125
Pistons wis k464x3
Dome 3.00
CnC Deck 9.230
Depends on how much boost. Im running 11:1 with 10#s. Get a good tuner and it will be fine. Im running 93 octane. Seeing no issues with knock or anything and it pulls like a freight train
15 Camaro SS- GPI max top end, ESS Vortech V3 9psi, ID 1050s, ZL1 pump, JMS bap, Long tubes, Corsa extreme, Circle D pro 5C, 391 rear, DSS carbon drive shaft, poly cradle bushings, tuned by Ted Jannetty and much much more
gunchamp is offline   Reply With Quote
Old 05-26-2021, 11:54 PM   #10
Lsguy
Drives: 2010 camaro
Thanks for the help... I do plan on keeping the Boost low when on pump gas and at the track the car will be on methanol. Sorry that's a newbie mistake I did not give enough info I was at work when I made that post.
I have put together a few cars before but mostly 2JZ stuff and it was all bolt ons. This is my first actual build.
I started this build with the intention to get my son into building cars and also to be able to upgrade later on to a aftermarket head and be able to make more power.
I got a question about lifters I ordered a set of Johnson 2116lsr three weeks later they're still not here when I called them they told me a good alternative was the morel 5290 I know that is not a short travel slow leak down lifter I don't think the 5290s will support the RPM in the future. Has anyone had any experience with those and what RPM are you turning them to
Old 05-27-2021, 03:20 PM   #11
stevieturbo
Drives: it changes
Was CR not discussed with the builder before you got to this stage ?
stevieturbo is offline   Reply With Quote
Old 05-27-2021, 05:34 PM   #12
AGP Turbo
Drives: All things Turbocharged
It will only cost you a few hundred dollars to change the pistons out to the right -15or20cc and sell your flat tops at a bit of a loss. Otherwise on pump gas you are going to be limited to roughly 10psi and that's a total waste of all the money you've invested. 150+whp more available on pump gas by going lower compression.
AGP Turbo is offline   Reply With Quote
Old 05-27-2021, 05:56 PM   #13
Lsguy
Drives: 2010 camaro
Yes compression ratio was discussed. I'm not to concerned with Boost on pump gas my concern was would I be able to drive it at all on pump gas. I do plan to race it at the track so it will be on methanol when under high boost. Like I said I want to do some drag week type events and I live right outside of Sevierville Tennessee so take it to the rod runs. If I could run
10 pounds of boost are less on the street that would be fine. Could I set it up to spray meth like a water methanol kit when on pump gas to keep it happy.
Old 05-27-2021, 05:58 PM   #14
ttshovel
ttshovel's Avatar
You might wanna do your research on what it takes to run methanol as your primary fuel. It's not as easy as you'd think. You'll need a 10gpm fuel pump minimum
