Old 05-23-2021, 06:37 PM   #1
blazzin1
blazzin1's Avatar
Drives: 2010 2SS/RS R6P
P0171/P0174 - System too lean (bank 1 & bank 2)
My 2010 SS LS3 M6 (FBO) is throwing codes P0171 & P0174 - System too lean (bank 1 & bank 2). Seems to still run good, except I did notice that when I'm pulling up to a stop light and take it out of gear, it will idle up really high, like around 1800 rpm. What's weird is that once the car rolls to a complete stop, the idle will drop down to normal. I've inspected pretty good for any obvious vacuum leaks, and couldn't find anything. Any recommendations on what to look at next???
blazzin1 is offline   Reply With Quote
Old 05-23-2021, 09:31 PM   #2
PaulsSS
Drives: 15SS Camaro
Good place to start is the fuel trims, and fuel pressure
PaulsSS is offline   Reply With Quote
Old 05-25-2021, 04:59 PM   #3
Mouse330
Mouse330's Avatar
Drives: 2011 2SS, 2006 GMC Sierra
MAF sensor. Disconnect it and see if there's a change
Have you made any changes to you intake system? Throttle body?
Gas quality?
Mouse330 is offline   Reply With Quote
Old 07-18-2021, 12:25 PM   #4
DavidH
DavidH's Avatar
Drives: 2010 Camaro 2SS
I'm currently trouble shooting the same thing. Same codes and that high idle when stopping. I've replaced the injector orings and manifold seals, still persists.
Run a vaccum test or smoke test. You can build a smoke tester for cheap with a pickle jar, soldering iron, and two hoses. I ran this test, a boost leak test, and had no issues. My conclusion is pointing toward something electrical (MAF/o2 sensors), or the fuel pump.
Have you tested fuel pressure at the schrader valve yet?
Has the MAF been cleaned? New intake installed?
Do you have access to a code scanner that will show long term fuel trims and see o2voltage?
DavidH is offline   Reply With Quote
Old 07-18-2021, 01:24 PM   #5
G8One2
Drives: 2014 Camaro 2SS
Is this a stock car? Modified? What mods if any?
G8One2 is offline   Reply With Quote
Old 07-22-2021, 06:22 AM   #6
DavidH
DavidH's Avatar
Another item to check would be exhaust manifold gaskets. I checked mine yesterday and multiple bolts were finger tight. I believe this can cause a leak and induce additional air before the O2 sensors. In pair with this I am seeing a very erratic reading from the front o2s.
If you have access to a DTC scanner I would monitor fuel pressure at the rail during prime and idle, O2 sensor voltage during open loop, and long term fuel trims
