Old 05-24-2021, 08:48 PM   #1
JBZL1
JBZL1's Avatar
Drives: 2012 ZL1
What mileage did you replace your brakes ?
Just curious at what mileage are the stock brakes going at? I don't ever track my car but it has 50miles on it now and the brakes are still great! They don't pulse or pull..
So what mileage and did you replace them with stock or aftermarket ? Does it matter it the car is an auto or manual I wonder ?
Thanks guys !
2012 ZL1 preproduction car #13
ROTO-FAB intake / IC reservoir , 2.85" upper , ported inlet
JBZL1 is offline   Reply With Quote
Old 05-24-2021, 11:13 PM   #2
Triple5even813
Learner of things
Drives: 2013 ZL1 M6 coupe, black
I replaced my brake pads with Powerstop Z26 pads very shortly after getting the car at 6k miles. I just couldn't stand the constant brake dust cleaning. Lost a little bit of stopping power, but greatly reduced the dust. About 20k miles later, I installed the Carlyle racing 15" conversion Wilwood brakes and haven't done anything to them for about 25k miles.
2013 M6. Cammed, straight piped, 17# boost, E85. Tuned by CHenry Motorsports. 825rwhp @ 6450, 812 rwtq @ 3500. Stock unported blower, stock heads, stock bottom end, stock throttle body. Boost only, no meth, no nitrous
Triple5even813 is offline   Reply With Quote
Old 05-25-2021, 08:51 AM   #3
12oclockshadow
Drives: 2012 ZL1 M6
Yes brake dust is pretty bad with stock pads. Been thinking of changing mine for same reason, less brake dust. My car has 23k and brakes feel great still.
FBO. Cammed. Flex fuel.801whp/741wtq on e85
12oclockshadow is offline   Reply With Quote
Old 05-25-2021, 03:45 PM   #4
Vicster
Drives: 13' ZL1
25 miles
Replaced mine after 25 miles with Hawk ceramic pads. No problems with dust and the is grip smooth and predictable.
Vicster is offline   Reply With Quote
Old 05-25-2021, 04:55 PM   #5
beersngars
Drives: 2012 ZL1
Replaced mine at about 2500 miles with the Hawk ceramic pads all around. Less brake dust but still alot. I wouldn't buy them again.
beersngars is offline   Reply With Quote
Old 05-25-2021, 07:18 PM   #6
JBZL1
JBZL1's Avatar
Drives: 2012 ZL1
Thanks for the info guys! It seems like the pads are getting changed out fairly early in the mileage, what about rotors ? What's everyone doing for them?
Old 05-25-2021, 10:00 PM   #7
Triple5even813
Learner of things
My car is at 47k miles now and the front rotors still look great, although they are a bit heat scorched from quite a few 140+mph stops lol
Old 05-25-2021, 11:08 PM   #8
Little Walter
Drives: ZL1
After the initial wear in with the HAWKS ceramics the dust became very light, just curious of how long have you had yours on.
Little Walter is offline   Reply With Quote
Old 05-26-2021, 07:46 PM   #9
tartagliazl1
tartagliazl1's Avatar
Drives: 2013 zl1 vert
i have 22,000 on my factory pads, they are getting thin though.
22% lower/ 2.5 upper/ 2” headers/ cat delete/ x-pipe/ 2 gallon x tank/ 100-3 pump/ fic 1300/ dsx aux kit/ 103mm throttle body/ big gulp 5” intake/ meth kit/ prometh lid injection/FI interchiller/ 160* stat/ ngk-7/ msd wires/ elite catch can/ tsp cam/ Che trunnions/ ported supercharger/ 1/2” lid spacer/ cnc,milled ported heads/ brick mod/BMR toe and trailing arms/ 781hp 748 tq SAE @17.3lb on a loaded dyno.
tartagliazl1 is offline   Reply With Quote
