![]() Drives: 2014 Camaro 1SS (A6 Ashen Gray) Join Date: Sep 2019
Door plug part number
Hi, all!
In my 2014 Camaro SS, I noticed that there's a door plug missing from my driver's side door. It looks like the part number is 314327891, but I can't seem to find it for sale online. ![]() For the moment, I've covered the hole with some automotive masking tape. Could someone please help me confirm whether I'm searching for the correct part number? Currently, I think I might only be able to get this part by going to a dealership's parts center. I've attached some photos in case it would help with figuring this out: The plug itself, driver's door, passenger's door.
Mod list: GPI SS3 camshaft (VVT delete), ZL1 Fuel Pump, FIC 60 lb injectors, Tru-Cool 40k tranny cooler, Circle D 3600 triple disc (billet flexplate), GPI Rod Mod, Bo White ported TB, Variant Helium wheels, CAI cold air intake, Kooks 1 7/8" LTH w/ high flow cats, Ridetech HQ coilovers, BMR sway bars, BMR delrin subframe bushings, Hendrix offset poly diff bushings, Borla S-Type axle-back, Holley EFI Fuel Rails, Elite Engineering E2 catch can, Umbra LED Taillights, Anvil Auto carbon fiber notch spoiler, Kenwood DMX9707S head unit, some minor interior/exterior appearance mods.
Last edited by phoenix78; 05-25-2021 at 12:31 PM. Reason: Removed some unneccessary line spacing |
![]() Drives: G8 Join Date: Mar 2012
Ask a dealer to give you the updated part number....or measure the hole diameter and Google rubber hole plug with that dimension
Sent from my Pixel 4 XL using Tapatalk |
#3 | |
Will do! Thanks so much!
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: SUMMIT WHITE 2SS/RS CAMARO Join Date: Feb 2008
Numbers lister on a part are rarely a part number. Remember GM doesn't make
most of their own parts.
#5 | |
Ah, thanks for the heads up!
#6 |
SoCal C5 Family Member
Drives: 1996 Z28 SS & 2014 ZL1 Join Date: Apr 2009
The part number you are seeking is GM 24436714.
PLUG,FRONT SIDE DOOR OUTSIDE HANDLE ACCESS HOLE.
Vance Chula -
1996 Camaro Z28 SS #1688 2014 Camaro ZL1 Coupe #1956 |
#7 |
Banned
Drives: 2010 LS Join Date: Feb 2021
Did a search on ebay for the part# ON the plug he has:
https://www.ebay.com/itm/152072419954 One listing, but one of those plugs are it. Searched eBay on the updated part:GM 24436714 'Bout a half dozen, and way over priced listings. |
| Tags |
| door, plug, weather |
