Old 05-26-2021, 11:36 AM   #1
kmarshall2121
kmarshall2121's Avatar
Drives: 2012 45th Anniversary Edition
Trunk release is possessed
So, recently happened and is getting progressively worse. Hit the button for the trunk release from my drivers door, and it will click multiple times, sometimes the trunk lid will release - sometimes not. Then other times, if it did release, the lid will not latch when closing it. I have to push the button a couple more times to get the 'cycle' back in line, if that makes sense. Any thoughts on what is causing this? The button itself? Actuator within the locking mechanism, if there is one..? help...? Thanks
kmarshall2121 is offline   Reply With Quote
Old 05-26-2021, 11:54 AM   #2
xstuntman
Drives: 2012 Victory Red LFX
Shoot a little WD40 in there and see if it helps, if so a little white lithium wouldn't hurt.
'18 SS wheels, colored matched Heritage grille, actual driving lights, ZL1 strut tower brace, GM Performance billet aluminum fuel door, victory red rotors and calipers, 1/4 window American flags, splash guards, AEM dry panel air filter, Hot Wheels steering wheel and seat covers, Hot Wheels exterior emblems.
xstuntman is offline   Reply With Quote
Old 05-26-2021, 11:57 AM   #3
kmarshall2121
Not sure that's it - what is making it click multiple times?
Old 05-26-2021, 12:02 PM   #4
xstuntman
Its dirty, gummed up, and the body module is still trying to unlock would be my guess.
WD40 will wash it out and temporarily give it some lube.
Old 05-26-2021, 01:42 PM   #5
SSFury
My Road Rage is Legendary
SSFury's Avatar
Drives: 2011 IOM 2SS/RS "Fury"
Mine does this occasionally as well. Will try some white lithium.
Every Time You Buckle Up In That Car, Tonight Might Be The Night That You Die.
SSFury is offline   Reply With Quote
Old 05-26-2021, 02:16 PM   #6
SSEssence
Instagram: Sangstah
Drives: 2019 Camaro 1LE
If it clicks, the button is doing its job, looks like the mechanism is gumming up.
SSEssence is offline   Reply With Quote
Old 05-26-2021, 03:10 PM   #7
joekono
joekono's Avatar
Drives: Camaro Convertible 2014 1LT
I can tell you first hand about this "button" because I just dealt with it this past weekend when I installed my yellow interior trim kit(pictures soon of the kit install). As for your issue, that was the only switch that I had an issue with when I had the door panel off and I had to pull it apart to get the wire harness to release. This gave me an idea of how the button works. When you press down, there is a rubber piece that "springs" back and forth with a round metal contact that activates the circuit when you press down. I can say, the rubber piece is a little flimsy and it had to be perfectly lined up when I closed the switch. There's a good chance that it gets "stuck" in the contact position when you push it down or vice versa because it is starting to rip. Now the idiot in me noticed after I installed the kit that my mirrors were not moving and of course I forgot to plug in that connector. I can take a door panel off of a Gen5 pretty fast now . Hope this helps and good luck!
joekono is offline   Reply With Quote
Old 05-29-2021, 08:25 AM   #8
JD555
JD555's Avatar
Drives: 2014 2SS RS, 6 sp man
Are the little springs that pop it open still there? They look like switches and should be 2. Mine keep popping inside the truck lid cover. I used to take it off to get them out now I just pry the cover up and they fall out and I stick them back in the hole.
JD555 is offline   Reply With Quote
Old 06-02-2021, 04:29 PM   #9
kmarshall2121
has nothing to do with those - the mechanism keeps clicking, and occasionally when it does, it stcks in the unlocked position and the trunk lid wont close. I have to cycle through by pressing the button again a few times...
Update: seems the WD40 trick worked. Must have been gummed up, or sticking somehow... Thanks!
Old 06-02-2021, 04:52 PM   #10
xstuntman
Good to hear.
What did we do before WD40?
Old 06-03-2021, 09:07 AM   #11
ElderJ
ElderJ's Avatar
Drives: 2014 Camaro 1LT
Originally Posted by xstuntman View Post
Good to hear.
Spit
ElderJ is offline   Reply With Quote
Old 06-13-2021, 09:03 PM   #12
Fogey
Fogey's Avatar
Drives: 2011 2SS/RS A6, IOM
Thought this thread might be about my cars possessed trunk. Periodically I get into it in the garage and find from the dash that the trunk is open though I know I closed it the last time I used the car. I assumed it was my fob getting pushed while in my pocket. Today I walked behind it in swim trunks, no pockets, no fob and the trunk popped open.
The only thing I can think of is that it is picking up a random signal from somewhere on our street.
It never happens with the doors. Just the trunk.
"...when the driver steps on the gas, I want him to
s--t his pants."
Enzo Ferrari
Fogey is offline   Reply With Quote
Old 06-15-2021, 01:01 AM   #13
Car Nation Videos
YouTube-Car Nation Videos
Car Nation Videos's Avatar
Drives: 2010 Chevrolet Camaro
Weak battery Caused my trunk to act up. Replaced the battery and now it works perfect.
Car Nation Videos is offline   Reply With Quote
