Old 05-30-2021, 07:48 PM   #1
Genob4c
Genob4c's Avatar
Drives: 2015 Camaro Z/28
Michelin Pilot Sport A/S 3+ All-season tires
Hey, Folks.
My recently aqcuired Z/28 with 3,200 miles still has the original Trofeos on. I was planning on keeping them on for the summer, but there is clearly some dry-rot cracking around the outside perimeter, so I'm not taking any chance on a catastrophe.
I don't track the car at all. It's not a daily driver, but I will drive it frequently enough just for fun. I'd like an all-season tire I can put on and not worry about cold temps and rain. Michelin now has this Pilot sport A/S 3+ All-season tire. I've always had good luck with Michelins. My question is this...
Can I run 325s all around with this tire? For some reason, they don't offer a 305/30/19, only the 325/30/19. I've read many threads on this topic. Most all say 325s are fine on the rear, but opinions seem to vary on the front. I understand all 325s are not equal in width, depending on the manufacturer.
Has anyone else tried these all-season Michelins? I'd really like the same tire all around. I suppose I could put 305 Pilot Sport 4 S on the fronts. What say you guys?
Geno
Now: 2015 Z/28
Former:
2013 ZL1 Vert – Crystal Red
1978 Corvette Pace Car
1969 Pace Car
1969 Z/28 – Cortez Silver, 1974 LT/Z28 Blue
1974 Z28 Dark Green , 1976 Camaro Type LT – Black
1980 Z28 – Charcoal, 1981 Z28 – Dark Blue
1981 Z28 – Claret, 1982 Pace Car
1986 IROC – Red, 1993 Z28 – Red
1996 Z28 vert, 1998 Z28 Dk Blue
2002 B4C 2004 Vette – LeMans Blue
2008 Vette - CRT
2011 Camaro Pace Car
Genob4c is offline   Reply With Quote
Old 05-30-2021, 08:31 PM   #2
Genob4c
Genob4c's Avatar
Looks like now they're up to Pilot Sport AS 4. Updated version of the AS 3+. The same question applies.
Now: 2015 Z/28
Former:
1969 Pace Car
2008 Vette - CRT
Old 05-30-2021, 11:29 PM   #3
CAMARO_HEAVEN
Big John
CAMARO_HEAVEN's Avatar
Drives: Wife 2013 Camaro 2SSRS / ME?
I had 295 30 19 Michelin pilot super sports on the front of mine with 325 30 19 on the rear and did well for me
CAMARO_HEAVEN is offline   Reply With Quote
Old 05-31-2021, 01:26 AM   #4
ariZona28
Give speed a chance
ariZona28's Avatar
I run the Michelin PS 4s on my Z and they are fantastic BUT as stated they are a "summer" tire. I don't drive on them in temps below 40 degrees.
ariZona28 is offline   Reply With Quote
Old 05-31-2021, 03:44 AM   #5
JThorn
JThorn's Avatar
Drives: 15’ Chevy Camaro Z/28
I just put 325/30/19 Michelin Pilot Sport Cup 2’s on all four corners a few weeks ago and I can say that I have not had any issues at all and I am using the factory specs as far as the caster/camber alignment. I haven’t done any super aggressive driving yet (track days / AutoX )…but have thrown it around the local back roads a little bit. I have not had any clearance issues at all. You can look up the tire specs on Michelin’s page and see if they are the same dimensions or close. Prior the car had the Hankook V12’s 305’s on all four and I really liked those tires. I just swapped for up coming events.
JThorn is offline   Reply With Quote
Old 05-31-2021, 08:01 AM   #6
Genob4c
Genob4c's Avatar
That's why I'm looking at the AS version. I'll need to be able to drive in some low temps. Never snow, though. That's what my Wrangler is for.
Now: 2015 Z/28
Former:
1969 Pace Car
2008 Vette - CRT
Old 05-31-2021, 08:07 AM   #7
Genob4c
Genob4c's Avatar
The Michelin site says the 325 AS I'm wanting are 13" wide. Do you happen know the width of your 325 Sport Cup 2s? 13" sounds pretty wide to me. Thanks for the infom.
Now: 2015 Z/28
Former:
1969 Pace Car
2008 Vette - CRT
Old 05-31-2021, 08:30 AM   #8
Genob4c
Genob4c's Avatar
I think I found your cup 2s info. It also says 13", so I think I'm probably good to go. Are you also using the stock Z/28 wheels? They're 11" wide up front and 11.5 in back, correct? Thanks.
Now: 2015 Z/28
Former:
1969 Pace Car
2008 Vette - CRT
Old 05-31-2021, 02:02 PM   #9
JThorn
JThorn's Avatar
Yes I am running the stock rims 11 upfront 11.5 rear and here is the info on my tires.
Old 05-31-2021, 02:04 PM   #10
JThorn
JThorn's Avatar
A heads up the look of the 325 are pretty aggressive in the front, make sure you have the flares to detour rock chips up the side.
Old 05-31-2021, 03:11 PM   #11
Genob4c
Genob4c's Avatar
Thank you! What's the difference between tread width and section width?
What did you do for flares?
Now: 2015 Z/28
Former:
1969 Pace Car
2008 Vette - CRT
Old 05-31-2021, 06:30 PM   #12
JThorn
JThorn's Avatar
Section with would be the widest part of the tire ( sidewall to sidewall ) and then the tread would be obviously the widest of the tread. This is when mounted on a certain certain size/width rim. As for flares I bought the longer ones from ZL1Addons. Do a search for rock guards on here that’s where I found out lol.
Old 05-31-2021, 07:13 PM   #13
Genob4c
Genob4c's Avatar
Great. Thanks. I really appreciate the help.
Geno
Now: 2015 Z/28
Former:
1969 Pace Car
2008 Vette - CRT
Old 05-31-2021, 10:34 PM   #14
JThorn
JThorn's Avatar
Anytime hope it helps ��������
