Old 06-04-2021, 05:57 AM   #1
aaberg
30th conv & 45th 2SS conv
aaberg's Avatar
Drives: 1997 30th conv & 2012 45th conv
Urgent: Will W-pistons fit a J-engine?
My car is a Camaro 2012 2SS automatic with original L99-engine. Vin 2G1FK3DJ7C9105243
I will remove the Auto Fuel Management (AFM), keep VVT and restore engine. I have ordered pistons from Summit and just got a call from my speed shop that the pistons I have ordered are plain at the top and don't have any place for the valves, that original old pistons have.
Looking at Summits website: https://www.summitracing.com/parts/S...%2byear%3a2012
The text says these pistons are for engine W but nothing to find out about engine J.
I will also add a cam stage 1 kit: https://www.summitracing.com/parts/cca-mk189-301-13
So, the bottomline and question is: Will these pistons fitt my L99-engine?
(Yes, I know they are over borred .020).
aaberg is offline   Reply With Quote
Old 06-04-2021, 01:48 PM   #2
InFiD3ViL
InFiD3ViL's Avatar
You would likely need to get rid of the VVT to run with the flat top pistons (LS3 conversion). VVT needs pistons with valve reliefs for proper PTV. This is a very generalized answer, so hopefully someone else will comment.
Old 06-04-2021, 04:37 PM   #3
Rock-It Man
376 cubic inches of fun
Rock-It Man's Avatar
Drives: 2023 Camaro ZL1 A10
You need the scooped out pistons to accommodate VVT.
Do not put in the flat topped pistons, the valves will crash into them.
And why get rid of VVT? It gives you a nice flat torque curve that is great for low end torque.
Rock-It Man is offline   Reply With Quote
Old 06-04-2021, 08:58 PM   #4
InFiD3ViL
InFiD3ViL's Avatar
Right, I agree. I was only stating he would have to get rid of the VVT to run those pistons. The better solution would just be to get the correct valve relieved pistons.
Old 06-04-2021, 09:30 PM   #5
Chris49066SS
Chris49066SS's Avatar
Drives: 2010 SS L99
If I were that deep I would just forge the bottom end, thats just me though, just my opinion.
Previous PB:11.079 @ 122.99mph.. New setup time: TBD
The 11.079 pass: https://youtu.be/pz27Zq54t_E
Build thread - www.camaro5.com/forums/showthread.php?t=555371
Chris49066SS is offline   Reply With Quote
Old 06-04-2021, 10:49 PM   #6
Batmanntexas
Batmanntexas's Avatar
Drives: 2012 Camaro SS (2SS)
You could possibly have those pistons fly cut for the PTV. Not sure how much material there is in the crown though, just a thought.
745RWHP/634RWTQ on 93 @ 10psi
806/676 on E85 @ 10psi
Currently @15-16psi....
COTW 9/8/14
Batmanntexas is offline   Reply With Quote
Old 06-05-2021, 12:39 AM   #7
lemontwist
lemontwist's Avatar
Drives: 12 2SS/RS L99,11 2SS/RS LS3totaled
i had my dod/afm tuned out(makes it a different car) it seemed like like unnecessary work going into the motor unless you are going cam swap. imo with a gear change and a tune the l99 is a good set up. i have had a few friends say my l99 car is faster than my ls3 car was still the ls3 was more fun mainly because the tr6060 and 3.42's. i hate to say it but cam, converter and gears makes the l99 a STOUT performer....quite possibly better than most ls3 cars.
lemontwist is offline   Reply With Quote
Old 06-05-2021, 05:12 AM   #8
TheFlyingBananaSS
Evil Genius of Chevrolet
TheFlyingBananaSS's Avatar
Drives: 2017 Z06, 2019 XTS, 2013 SS
I agree.
GPI SS2 VVT cam, ECS Novi 1500 supercharger, Corsa Extreme, Detroit Speed and BMR suspension, Circle D triple disc, Melling oil pump, LS2 chain tensioner, ATI 10% UD, DSX E85 kit, High Energy coils, BTR springs, LS2 Lifter trays, Titanium retainers, hardened push rods, FIC 1000 injectors, ZL1 pump, Mighty Mouse catch can, AEM gauges, Tial BOV, Richmond 3.91 gears, Custom gauge bezels, Speed Engineering headers, Stainless Works HF cats, DSX Aux pump, 710rwhp on E85.
TheFlyingBananaSS is offline   Reply With Quote
Old 06-05-2021, 05:53 AM   #9
aaberg
aaberg's Avatar
Where to find J-pistons?
Thanks for your advice. Seems like I need to swap J-pistons since I want to keep VVT. Can't find any at Summit and Rockauto doesn't have them in stock. Any suggestion where to find them?
Old 06-05-2021, 11:16 PM   #10
Rem0v3r
Drives: 2013 ss2 vert l99
If the cam will work in an ls3 then it will work in an l99.. im also assuming you're getting the rotating assembly balanced..
If your planning on boost at all then I strongly recommend resleeving the block while you're in there.
Rem0v3r is offline   Reply With Quote
l99 engine, pistons
