Old 06-07-2021, 11:21 AM   #1
MIKZ28
Drives: 2019 Camaro ZL1 2004 Pontiac GTO
CAMARO ZL1 ILE CONVERTIBLE?
Aside from the structrual stiffness and other limitations I understand why GM doesen't sell a Camaro ZL1 1LE convertible. But if I were to purchase a Camaro ZL1 convertible what parts and changes would I have to make to it to convert it to a ZL1 1LE? I know there are body changes like flares and wings but other than the appearance changes what else is different. Thanks in advance.
MIKZ28 is offline   Reply With Quote
Old 06-07-2021, 12:58 PM   #2
ZMEnow
Drives: ZL1, 2013, tri-coat-red, manual
1st you would have to head over to the 6th Gen forum because they never made a 5th Gen ZL1 1LE. Best of luck..
ZMEnow is offline   Reply With Quote
Old 06-07-2021, 01:44 PM   #3
ariZona28
Give speed a chance
ariZona28's Avatar
Just keep your Z/28.
ariZona28 is offline   Reply With Quote
Old 07-11-2021, 05:32 PM   #4
yellow69z28rs
Drives: 2013 ZL1 Convertible Black
Send a message via AIM to yellow69z28rs
Make you ZL/28 convertible
JRE 750 HP package
Rag Top Rob
yellow69z28rs is offline   Reply With Quote
Old 07-14-2021, 05:37 PM   #5
Vigilante375
Drives: 2018 Camaro ZL1
The 6th gen ZL1 convertible doesn't have the eLSD (not enough room under the car). So with it being a convertible, not many tracks will allow a convertible to run.
To covert a coupe ZL1 to a 1LE you have to change out the suspension (shocks, struts, bushings, etc), put on the added aero package, get the transmission tune the 1LE has and then the rims and tires.
With the convertible, you'll HAVE to add the eLSD. But you can't because there is no room and without that, you won't have performance track management aka PTM.
Vigilante375 is offline   Reply With Quote
