06-13-2021, 04:08 PM | #1 |
Drives: 2015 Z-28 / '13 Howe TA2 Camaro Join Date: Jul 2014
Rear end Yaw/squirm on Acceleration / Deceleration Stumped...
I noticed after tire replacement (Goodyear F1) and bedding of new break pads that suddenly the rear of the car seems to side squat under acceleration and jumps back on deceleration. Very unsettling feel. Put her on jack stands and didn't see any apparent issues. Tire pressures were all within 1 PSI so not the issue.
Ideas? I'm stumped. All of this is without application of breaks. Anybody experience this before? Thanks! |
06-13-2021, 04:55 PM | #2 | |
Build Date - Dec 08, 2014
Drives: 2015 Z/28, #1007, Black A/C Stereo Join Date: Oct 2015
https://www.camaro5.com/forums/showthread.php?t=494274 |
06-13-2021, 06:07 PM | #3 |
Drives: 02 Camaro B4C Join Date: Nov 2016
How many miles are on the car?
A man's garage is his castle
1969 Camaro SS 1970 Camaro SS 2002 Camaro B4C 2014 Camaro SS Dedicated Track Car 2015 Camaro 1SS 1LE 2008 HHR SS 1996 Silverado Crew Cab Long Bed Dual Rear Wheel |
06-13-2021, 06:11 PM | #4 |
06-13-2021, 06:14 PM | #5 | |
06-13-2021, 06:21 PM | #6 |
Drives: '15 Z/28 #0270 Join Date: Jan 2017
Might be the tires. Which Goodyear F1's did you get? I have the Supercar 3R's and once up to temp they are good.
06-13-2021, 10:36 PM | #7 |
Drives: 2015 z28 Black w/ac #645 Join Date: Jan 2017
Loose suspension bolt
Go to search engine on here and type ( loose suspension bolt) and see if this could be your issue. I checked mine when this came out but mine were ok.
06-16-2021, 06:44 AM | #8 |
Drives: . Join Date: Jun 2016
I had rear-passenger side inner tie-rod bolt come loose midway through a trackday which gave me scary symptoms like you describe for half a lap!
Came back into the paddock and re-tightened with alignment by eye. and then a proper shop alignment as soon as I was able to and no further issues since. |
