![]() ![]() ![]() ![]() Drives: 2011 Inferno Orange Camaro 2SS/RS Join Date: Nov 2011
DRL Harness
I'm looking for a DRL harness to keep my DRLs on at night. I have a 2011 2SS/RS
Can someone tell me the difference between the $11 Amazon, $15 Phastek and $62 Gen5diy harness? It looks like they all do the same thing and are all plug n play |
![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2012 Chevrolet Camaro l99 Join Date: Aug 2020
I was wondering the same thing but I went ahead and ordered one from Amazon. I get it tomorrow and I'll let you know how it works out.
DSS Pistons, Eagle ESP L19 Rods, ARP Head and Main Studs, TSP PRC CNC Ported Heads milled .030, Cometic .040 Head Gaskets, GPI SS3 VVT Camshaft, GM Racing Lifters, CHE Trunnions, Melling 10355HV Oil Pump, Cold Air Inductions CAI, Fast LSXR Intake Manifold, Nick Williams 103 TB, TSP Longtubes, ZL1 Fuel Pump, Mishimoto Radiator and Oil Cooler, 3600 Circle D Converter, Tru Cool 40k Tranny Cooler, Fluid Dynamics Balancer, EBC 3GD Rotors with EBC Bluestuff NDX Pads, Bilstein B6 Shocks / Struts with Eibach ZL1 Drop Springs
Build Thread https://www.camaro5.com/forums/showthread.php?t=609817 |
Thanks! If you say it works I will pull the trigger on one as well. I don't get the huge price differences, or maybe i do.
![]() Drives: 2010 2SS/RS, VR ext/Blk Int Join Date: Jul 2012
Why do you want the DRLs on at night? Personal preference? I replaced my DRL bulbs with LEDs. I'd be afraid they would be too bright.
I got my harness from Phastek and the P13W Plasma LED bulbs too and what a difference it made!! They are about the same color as the stock HID headlights..
#6 |
![]() Drives: 2011 Camaro SS Join Date: May 2021
I picked up the harness from Amazon and installed it tonight. It works perfectly.
#7 |
![]() Drives: 2011 VR SS Vert Join Date: Aug 2015
I got the drl harness from amazon but went with gen5diy for the always on halos harness
#8 |
![]() Drives: 11 camaro 2lt rs Join Date: May 2008
Question about this harness. Do the DRLs work as normal during the day, or do you have to turn the headlights on? Also, will they stay on with just the halos turned on?
#9 |
Yes and yes, unless you turn them off by the switch, then they will not come on at all until the next time you start the car..
#10 |
Got the Amazon drl harness installed this morning and it works just fine.
#11 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: '16 2SS Join Date: Apr 2011
Depending on where they come from, make sure they have wire seals. You should see white and blue silicone rings around the wires where the go into the rear of the connectors. If not, they will eventually corrode and fail.
#12 |
![]() Drives: Chevrolet Camaro SS Join Date: Dec 2021
Dual Harnesses
#13 |
![]() Drives: 2013 Camaro SS Vert Join Date: Apr 2019
