Old 06-14-2021, 03:05 PM   #1
dma05
dma05's Avatar
Drives: 2011 Camaro 2SS/RS
Mighty Mouse Wild - Routed Correctly?
I just recently finished my Heartbeat supercharger install and added a Mighty Mouse Wild catch can as well. I wanted to make sure I routed it correctly.
I have the dirty side going from the oil breather and the clean side going into the inlet of the Supercharger.
The valley cover is plugged and so is the passenger side valve cover barb.
Also, I have the driver side valve cover barb going to the inlet of the air intake just after the air filter.
Thanks for any input.
Allen
2011 Camaro 2SS/RS
dma05 is offline   Reply With Quote
Old 06-14-2021, 03:47 PM   #2
dreksnot
Served USN - Atomic Chimp
dreksnot's Avatar
Drives: 2021 Camaro ZL1 1LE A10 (stock)
That looks good.
What do you use the car for? Any autocross or road course?
> Past Builds: 2013 Twin-Turbo LSX434 M6 - 1,359rwhp daily
dreksnot is offline   Reply With Quote
Old 06-14-2021, 03:50 PM   #3
dma05
dma05's Avatar
I just use it for pleasure This is my project car. I do all the installs myself (first time doing most installs). I just like knowing I have the power when needed. I'm far from a race driver and I don't pretend to be one. I just like having a car that sounds awesome and can GO!
Allen
2011 Camaro 2SS/RS
Old 06-14-2021, 03:50 PM   #4
URVINA42
Drives: 2015 Camaro 1LE
How did you do the coil relocation?
URVINA42 is offline   Reply With Quote
Old 06-14-2021, 03:55 PM   #5
dma05
dma05's Avatar
I bought the coil relocation kit from CBM along with the 24" Harness Extension. I mounted them to the frame, which can be tricky. Definitely not easy to change the coils if needed, but doable.
I had to custom cut the MSD wires it came with. That took some time to learn, but was easy after 1 was done. Use lots of lube to get the boots on the wires!
Allen
Allen
2011 Camaro 2SS/RS
Old 06-14-2021, 04:03 PM   #6
bayarea408
bayarea408's Avatar
Drives: T
i am plumbed up the same way on a L99 with my can since installation.
bayarea408 is offline   Reply With Quote
Old 06-16-2021, 12:48 AM   #7
dma05
dma05's Avatar
Would you guys recommend another catch can between the hose that is routed from the driver side valve cover to the intake pipe? Wouldn’t that pull oil into the intake and dirty up the throttle body and supercharger if bo catch can is in place?
Thanks!
Allen
2011 Camaro 2SS/RS
Old 06-16-2021, 04:35 PM   #8
hammdo
'It's an experiment'
hammdo's Avatar
I did that - run 2 catch cans:
-Don
747 RWHP 794 RWTQ
Old 06-16-2021, 05:02 PM   #9
dreksnot
dreksnot's Avatar
Thanks!
I run a smaller catch can off the rear of my driver's side valve cover. Not pulling any vacuum in it from anywhere though - just a vent hose from the valve cover to the can (for extra venting). I don't recall it capturing any oil.
Old 06-17-2021, 03:22 PM   #10
RupertPupkin
Drives: 2014 Camaro SS 1Le
eBay catch can, and put steel wool to catch oil vapors (just in case).
Hammdo—- that’s a mishimoto can right?
2014 SS 1LE Money Pit/ Forged 402
CAM 22X/24X, .619/.617, 113 LSA/ LS9 Heads
FIC 1200cc/DSX Aux Pump//McLeod RXT Clutch
730whp: 630Trq
RupertPupkin is offline   Reply With Quote
Old 06-17-2021, 06:10 PM   #11
dreksnot
dreksnot's Avatar
Hammdo
Does that top conversion fitting give you any benefit road coursing or autocross? Doesn't it just vent/drain to a larger reservoir but still capture a lot of oil. I filled my can up road coursing and autocross before spitting oil around the engine compartment and out the exhaust. I either have to weld a new fitting mid-section on my valve cover or empty the catch often when doing that kind of racing (I don't have the top conversion).
