Old 06-14-2021, 09:01 PM   #1
btwwat92
Drives: 1992 Red 25th Annversary RS
Rear differential mount broken
2011 Camaro SS M6.
Got the car up on the lift today to pull the rear differential for a gear swap and trutrac upgrade and found that the rear diff cover/mount was broken around the bushing. Anybody else ever seen this? Or know what could possibly cause this? Thanks in advance....
Sent from my SM-G935V using Tapatalk
btwwat92 is offline   Reply With Quote
Old 06-15-2021, 09:27 AM   #2
gtstorey
Damage when the stock bushing was cut out?
Old 06-15-2021, 12:33 PM   #3
dreksnot
Served USN - Atomic Chimp
dreksnot's Avatar
Drives: 2021 Camaro ZL1 1LE A10 (stock)
That edge looks so even and smooth, not like a fracture or break..... was it cut that way to install the new bushings because it looks that way to me (my 2-cents worth).
> Past Builds: 2013 Twin-Turbo LSX434 M6 - 1,359rwhp daily
dreksnot is offline   Reply With Quote
Old 06-15-2021, 04:39 PM   #4
btwwat92
Yeah, like I say, I don't know exactly what caused it. I was more curious if anyone had seen this before or had it happen to them. The bushing kit has been on the car for probably 2 or 3 yrs now.
Old 06-15-2021, 06:39 PM   #5
1JEWLDSSRS
1JEWLDSSRS's Avatar
Drives: 2011 SS-RS
As above, to me as well it looks like somebody cut it, nothing ever just breaks that evenly..
Old 06-16-2021, 11:40 AM   #6
Shtiggs
Drives: 2014 Camaro 2SS Manual
I would agree with the assessment that it was cut to remove/install the bushings, the corners and cut seem way to square to be natural break from a defect in casting or stress. Did you install the bushings (or pay for them to be installed by someone else) or was it like that from a previous owner?
Shtiggs is offline   Reply With Quote
Old 06-16-2021, 11:49 AM   #7
btwwat92
The bushings were installed by a shop. They were the ones that brought it to my attention on Monday when they went to start removing the diff for a trutrac install.
Old 06-16-2021, 11:58 AM   #8
dreksnot
dreksnot's Avatar
Well, it ain't right. But, apparently with the rear section missing, it hasn't destroyed the poly bushing and probably does perform mostly like it supposed to. With the open rear portion of the mount, the bushing can deflect out that opening. (I'm presuming those are poly (moderate durometer) and not Delrin (hard durometer) bushings)
Old 06-16-2021, 12:00 PM   #9
btwwat92
Yep, poly bushings. It just caught me off guard when they called about it since they were the shop that did the install.
Old 06-16-2021, 12:44 PM   #10
Shtiggs
You should find a new cover or get a PCE diff cover to replace that one during the gear and diff swap since that is really messed up. I used a bench grinder to put a slight chamfer on the bushing to help align and start them during the press.
PCE diff cover
Old 06-16-2021, 12:54 PM   #11
btwwat92
Already got one on the way! Thanks for the chamfer tip
