![]() Drives: 2018 zl1 Join Date: May 2015
—$35k—TX— 2015 Camaro 2SS/RS/1LE Twin Turbo 37k miles
$35,000 OBO LOCATED NEAR SAN ANTONIO, TX
Up for sale is my 2015 Camaro 1LE/2SS/RS in ashen grey metallic. The exterior and interior are in good condition but do take in mind it is a 6 year old car now so it has normal wear and tear. IT CURRENTLY HAS 37,XXX MILES on it and will be driven every so often so miles will change. Below will be a list of the mods that are done to the car. Prior to Aug 2018 the car was bone stock besides a short throw shifter. On the current setup it makes 680hp/619tq on e85(no meth) at only 6 pounds of boost. I wanted to keep it super safe so I went with the lowest boost it could hold. Peaks at about 6.2 at full throttle. I feel very confident that you could beat on it at this boost level for years and not have one hiccup and if you get bored at the 680hp then you can easily turn it up as there is a eboost 2 controller in the car. Will also come with a sparco racing seat and about 750$ worth of bmr suspension parts that I have yet to install. THE FULL TWIN TURBO BUILD WAS DONE 6 MONTHS AGO/500 MILES AGO. Mods list- “Cam life” - Aug 2018 - 20,000 miles Ported intake 231/238 cam w/ cam kit Cai cold air intake Texas speed headers Cutouts Dyno Tune by pat g - 470hp/413tq TWIN TURBO BUILD - January 2021 - 37,000 miles Agp twin turbo kit 57/57 journal bearing + Injector Dynamics 1300x + spark plug/wires Agp Twin fuel pump(-8 feed line,use stock feed as return) + flex fuel sensor Monster Triple disk clutch + billet bearing support Meth kit dual nozzle w/ trunk tank - installed but not spraying since I’m only at 6 pounds of boost. Eboost 2 boost controller You have new: •Johnson 2110 lifters •GM lifter trays •CHE Trunion Kit •GM LS9 head gaskets •ARP 12pt head studs •GM Valve cover gaskets •Valve seals & springs •TSP 7.3750 hardened pushrods •Exhaust Manifold gaskets •Mighty Mouse Catch can Valvoline vr1 20w-50 oil change 1-1-21 Installed by Jacob Wilhite Dyno tune by Pat G - 680hp/619tq on e70 6psi 630hp/577tq on 93 6psi June 4th, 2021 - BRAND NEW BATTERY Bray Krause Roll bar Rear seat delete kit - still have original seat |
![]() Drives: 2006 BOM GTO Join Date: Jul 2018
This car is amazing. I so wish I could buy this.
![]() Drives: 2015 Camaro SS/RS 1LE Join Date: Jun 2016
Check your PM's
Any interior pictures. Did not notice but does it have the OEM Recaros?
looks good!
