Old 06-21-2021, 12:53 PM   #1
InFiD3ViL
InFiD3ViL's Avatar
Tire recommendations for new wheels
So I finally ordered my wheels after having my car since 2016. I ordered a set of Gloss Black MRR M017s in 10/11" sizes, 20 inch with the standard +23/+43 offset.
I am currently running Firestone Firehawk Indy 500s on all 4 corners in the stock 245/275 sizes. To save money, my plan is to move the 275/40's from the rear to the front on the new wheels. They still have plenty of meat on them as I rarely spin em. But that leaves me needing something for the rear 11s. I really want to stay with a matched tire AND cannot stop obsessing over finally having my chance to get some 315s on the back. Issue is, Firestone doesn't make that tire in 315, but they do make 305/35s in the Firehawk Indy 500. The best part is they are semi affordable at $278.99 each. I prefer to not spend more than $650 for a set of 2 tires if possible.
I have been looking at other brand 315/35 tires but I'm not sure what would be the best way to do this. Should I just stay matched and just go with the 305/35 Indy 500's (Have been a really great tire), or should I go with something else in the 315 size to satisfy my massive tire desire? Been looking at a lot of other tires in the 315 size but not really sure what is the best blend of affordability and performance. Is mixing the tires really a bad idea or should I stop worrying about that? Are 315's much wider than the 305's or is it minimal? Obviously trying to stay with a Summer tire, as that is what the Indy 500s are.
Side note, tires are not my expertise as you may have noticed.
My incoming wheels for those that don't know the MRR M017s. They are the rep version of the 6th gen 1LE wheels:
Old 06-21-2021, 01:01 PM   #2
Redgt03
Redgt03's Avatar
Drives: 2011 Camaro SS
Just stick with indy in 305 - i also prefer matching tires, unless you are running a drag pack on the rear. The 305s will look much wider then the 275s so you will be happy.
2011 SS -GPI SS3 vvt, circle D 4c, 3.91 gears, solo mach xl exhaust, speed engineering headers, bo white ported throttle body, Roto fab intake, adm transcooler, elite catch can
Redgt03 is offline   Reply With Quote
Old 06-21-2021, 01:09 PM   #3
SSkat
SSkat's Avatar
Drives: 2010 Camaro 2SS
I would go with the 305 as well. You wouldnt even be able to notice the difference anyway. There will still be a bunch of meat out back! Also love the gloss black 1le's. I have oem ones and ive thought about getting them powdercoated.
SSkat is offline   Reply With Quote
Old 06-21-2021, 02:03 PM   #4
1JEWLDSSRS
1JEWLDSSRS's Avatar
Drives: 2011 SS-RS
I would do your best to keep the tires matched if you can. The 305's I think I saw are only 10mm narrower than the 315's. Also they will look pretty fat out back even though they are "only" 305's. lol. I have run the Conti Extereme Contact DWS06's ever since I have had my Camaro and love them. Had MPSS 335/30/20's on my 11.5" Ferrada's out back and the 275/40's Conti's on the Ferrada's 10.5 on the front and they both played nicely together.
Old 06-21-2021, 04:10 PM   #5
morepowerjoe
morepowerjoe's Avatar
Drives: 2012 Chevrolet Camaro l99
I have the 305 BFG's on the back and I wanted 315 but they don't make them in 315 either. So I went ahead and stuck with the 305. I would give you a picture of them but it doesn't do it justice. They are pretty meaty though.
DSS Pistons, Eagle ESP L19 Rods, ARP Head and Main Studs, TSP PRC CNC Ported Heads milled .030, Cometic .040 Head Gaskets, GPI SS3 VVT Camshaft, GM Racing Lifters, CHE Trunnions, Melling 10355HV Oil Pump, Cold Air Inductions CAI, Fast LSXR Intake Manifold, Nick Williams 103 TB, TSP Longtubes, ZL1 Fuel Pump, Mishimoto Radiator and Oil Cooler, 3600 Circle D Converter, Tru Cool 40k Tranny Cooler, Fluid Dynamics Balancer, EBC 3GD Rotors with EBC Bluestuff NDX Pads, Bilstein B6 Shocks / Struts with Eibach ZL1 Drop Springs
Build Thread https://www.camaro5.com/forums/showthread.php?t=609817
morepowerjoe is offline   Reply With Quote
Old 06-21-2021, 04:54 PM   #6
CPCNY
CPCNY's Avatar
Drives: 2010 2SS/RS, VR ext/Blk Int
Only 10 mm narrower which is just over 3/8". Putting it in perspective, you can barely notice the difference between 305s and 315s.
CPCNY is offline   Reply With Quote
Old 06-21-2021, 05:35 PM   #7
InFiD3ViL
InFiD3ViL's Avatar
Alright, well I think that pretty much settles it. I will save money this way as the Firestones are fairly inexpensive compared to some of the top tier brands.
Thanks everyone. 305's it is!
Old 06-21-2021, 08:01 PM   #8
TheFlyingBananaSS
Evil Genius of Chevrolet
TheFlyingBananaSS's Avatar
Drives: 2017 Z06, 2019 XTS, 2013 SS
I have no issues with 305 drag radials.
I also have a set of 305's for $100 but the shipping would kill the price.
GPI SS2 VVT cam, ECS Novi 1500 supercharger, Corsa Extreme, Detroit Speed and BMR suspension, Circle D triple disc, Melling oil pump, LS2 chain tensioner, ATI 10% UD, DSX E85 kit, High Energy coils, BTR springs, LS2 Lifter trays, Titanium retainers, hardened push rods, FIC 1000 injectors, ZL1 pump, Mighty Mouse catch can, AEM gauges, Tial BOV, Richmond 3.91 gears, Custom gauge bezels, Speed Engineering headers, Stainless Works HF cats, DSX Aux pump, 710rwhp on E85.
TheFlyingBananaSS is offline   Reply With Quote
Old 06-22-2021, 12:38 AM   #9
InFiD3ViL
InFiD3ViL's Avatar
I swear to god, I always seem to live across the country from the best deals.
Old 06-22-2021, 11:22 AM   #10
pnwdan
pnwdan's Avatar
Drives: 2014 2SS/RS
What you will notice is that the 305/35 is a smaller diameter than the 275/40. Not right now but if you replace the fronts later it will stand out like a sore thumb.
2014 2SS/RS LS3/M6
pnwdan is offline   Reply With Quote
Old 06-22-2021, 11:58 AM   #11
Royal Tiger
Drives: 2013 2SS/RS Convertible
What’s great about the 275/40-20 & 315/35-20 combo is they are the exact same diameter.
Royal Tiger is offline   Reply With Quote
Old 06-22-2021, 12:33 PM   #12
pnwdan
pnwdan's Avatar
Drives: 2014 2SS/RS
Exaclty
I just went from 305 to 315 when buying a full set because of that
2014 2SS/RS LS3/M6
Old 06-22-2021, 12:46 PM   #13
InFiD3ViL
InFiD3ViL's Avatar
So is this noticeable on the sidewall if you aren't looking for it, or is it more of a 'if you know' thing? Is it minimal or a big difference?
Old 06-22-2021, 12:47 PM   #14
morepowerjoe
I have the 305/35 and the 275/40 combo and to me it's barely noticable.
