Old 06-21-2021, 06:32 PM   #1
760bowtie
760bowtie's Avatar
Drives: 2014 1SS/RS, 2018 Silverado CC
AGP Fuel System Question
Anyone with the agp dual pump system, is there a way to switch the primary and secondary pumps? I have no fuel pressure when I try to turn my car on. Check all the fuses and relays and all look good. Also when I turn the key I can't hear the primary pump prime like it did before. TIA
AGP 57/57 turbos and Dual Pump System, NA Cam, McLeod RXT clutch, MGW shifter, ZL1 Rear End, BMR Trailing Arms/Toe Rods, Pegasus Solid Cradle Bushings 10.7 @140mph M6
760bowtie is offline   Reply With Quote
Old 06-21-2021, 06:38 PM   #2
Batmanntexas
Batmanntexas's Avatar
Drives: 2012 Camaro SS (2SS)
IF you are using a Hobbs switch to control the secondary pump, just jumper across those two wires and it will activate the second pump. You can also swap the relay control wires, but if your system is mounted like mine, mine are in the spare tire well, and I'd have to pull out a sub box, methanol tank, and other items....
745RWHP/634RWTQ on 93 @ 10psi
806/676 on E85 @ 10psi
Currently @15-16psi....
COTW 9/8/14
Batmanntexas is offline   Reply With Quote
Old 06-21-2021, 08:38 PM   #3
760bowtie
760bowtie's Avatar
Thanks for the help, second pump does kick on so my primary is done.
Old 06-21-2021, 09:26 PM   #4
joshnmn
2&THEHIT
joshnmn's Avatar
Drives: 5th Gen Camaro; 5th Gen Ram 3500
That sucks! Hope you get it straightened out
joshnmn is offline   Reply With Quote
