Old 06-23-2021, 09:50 PM   #1
smegal417
smegal417's Avatar
Drives: 2010 Camaro 2SS/RS
Fore double pump
I didn't know where else to put this but I'm having trouble finding an exact source.. car is a 2010 ss, I'm assuming blue wire is fuel level power, brown/white is fuel level ground, gray is power but what's the pink one??? Was going to use gray to power pump 1 is this correct?
Sent from my SM-G986U using Tapatalk
smegal417 is offline   Reply With Quote
Old 06-24-2021, 08:25 AM   #2
eLeSthree
Drives: 2011 Camaro SS 6sp
If you are not using the Fore Fc3 controller, you need to use a designated circuit with a 30 amp relay to power each pump. The primary pump's relay can be signaled with the green/white wire going into the FPCM. The secondary pump's relay signal can be a Hobbs or boost/pressure switch that comes on when boost is present.
You can't just use the existing wiring from the old pump. Is that what is pictured?
2011 Camaro SS---SOLD
TMS Dart 427 FED M311s, ESS Tuning G4 Blower, DSX Triple FP Assembly, DSX FF, FIC1300, Mcleod RXT 1200HD, Edlebrock Pro Flo XT
1158whp 1017wtq.
2010 CTS-V A6 - "Stock" SOLD
630whp 658wtq
2024 F-150 RCSB 5.0 4x4
waiting for tunes...
eLeSthree is offline   Reply With Quote
Old 06-24-2021, 09:52 AM   #3
BatmaroBeauty
BOOST OR BUST
BatmaroBeauty's Avatar
Drives: 2010 Camaro 1LT
Question Additional Question About Secondary Fuel Lines…
So I’ve gone through a few threads on the topic of a secondary fuel line which may be the solution to the fueling issue I’m experiencing of losing rail pressure over 6000rpm and getting a knock retard. I was wondering if someone please had the knowledge/time to explain to me briefly what it would encompass to run a second line, example: what additional parts are required to purchase and the installation process? I’m aware this is the V8 FI section and I am a FI 2010 V6 LLT, I just haven’t had luck finding a thread like described so was seeking more info about this topic. Maybe this exists already and I just haven’t found the right one. All info is appreciated and thanks in advance to anyone that contributes!
Batmaro=The Bane of My Existence ⠀⠀⠀⠀⠀ ⠀ ⠀⠀⠀⠀⠀⠀ ⠀ ⠀ ⠀⠀⠀ ⬋LIKE AND FOLLOW THE BUILD ON INSTAGRAM⬊
BUILD STATUS: LOADING BOOST . . .
BatmaroBeauty is offline   Reply With Quote
Old 06-24-2021, 10:13 AM   #4
gtstorey
I don't have an answer for your question, but since you engine is direct injected vs the multiport on the V8, your fuel setup will be quite a bit different.
Old 06-24-2021, 12:42 PM   #5
BatmaroBeauty
BOOST OR BUST
Understood, I was mainly just trying to gather some more information on the subject since I saw this thread about it being actively discussed so I’ll continue to do more research and digging around.. if anyone happens to stumble upon something please let me know!
Old 06-24-2021, 01:02 PM   #6
Greenhornet2
Greenhornet2's Avatar
Drives: 2011 Camaro 2SS LS3 Whipple
I'd call Jannetty racing. They do plenty with DI systems with superchargers, it will be the same principal. They may have experience with some FI V6's too.
Greenhornet2 is offline   Reply With Quote
Old 06-24-2021, 08:05 PM   #7
smegal417
smegal417's Avatar
I am using an fc3. You have to have a trigger wire for the pump and it says to use one off the factory wiring in the instructions.
Old 06-24-2021, 08:07 PM   #8
smegal417
smegal417's Avatar
Also, I need to hook the fuel level sender wires up to the factory wiring so I'll have a fuel level gauge
Old 06-25-2021, 06:48 AM   #9
eLeSthree
https://www.camaro5.com/forums/showt...=524169&page=3
Trigger wire for primary pump is the green/white wire on the FPCM harness. That wire needs to be tapped into before the FPCM, not at the pump harness. You don't want the FPCM to be controlling your new fuel system. ​
I cant recall the color of the wires for the fuel level gauge, but I can post a picture of the location in the harness.
1158whp 1017wtq.
630whp 658wtq
Old 06-25-2021, 06:51 AM   #10
eLeSthree
Hope that helps. The two small white wires coming out of the dsx fuel pump hat are for the level gauge.
(anyone with a good eye will spot that I have my hot/neutral wires backwards, lol. I can tell you they dont make much fuel pressure when you wire them wrong, hahah. live and learn)
1158whp 1017wtq.
630whp 658wtq
Old 06-25-2021, 11:55 AM   #11
Batmanntexas
Batmanntexas's Avatar
Drives: 2012 Camaro SS (2SS)
Sounds like you are running out of capacity on your HPFP. You might do some checking and see if anybody offers a larger bore/longer stroke HPFP, additionally, you may want to ensure that your low side pump is supplying enough fuel at high RPM to keep the HPFP fed adequately.
745RWHP/634RWTQ on 93 @ 10psi
806/676 on E85 @ 10psi
Currently @15-16psi....
COTW 9/8/14
Batmanntexas is offline   Reply With Quote
Old 06-25-2021, 11:44 PM   #12
smegal417
smegal417's Avatar
Thank you very much.
