Old 06-24-2021, 11:10 PM   #1
Hcd3ss
Drives: 2011 camaro 2ss/RS
Hard start, mild chirp
Recently deleted dod on twin turbo A6 SS. Used oem parts for replacements (L9H cam). Drove the car for a couple of weeks and after a bit of hard driving noticed a chirp,chirp, chirp coming from the engine. Checked the oil and had to add like 2.5 qts. Since this happened car has been harder to crank, and occasionally throws the service stabilitrack CEL. like the battery went bad.. but the battery is good. Do these cars have oil level sensors? How bad is 2.5 qts low? What would normally fail first from low oil level? I feel like it is something in the valve train, honestly.. so I’ll start trying to run down the issue this weekend.. but any advice or information would be greatly appreciated.
Hcd3ss is offline   Reply With Quote
Old 06-25-2021, 07:15 AM   #2
eLeSthree
Drives: 2011 Camaro SS 6sp
2.5 quarts is %30 of your total oil capacity. Its really really really low.
If you turbos are oil cooled, you would have needed to add oil...
The chirping sound is probably damage to a cam lobe and lifter.
Good luck.
2011 Camaro SS---SOLD
TMS Dart 427 FED M311s, ESS Tuning G4 Blower, DSX Triple FP Assembly, DSX FF, FIC1300, Mcleod RXT 1200HD, Edlebrock Pro Flo XT
1158whp 1017wtq.
2010 CTS-V A6 - "Stock" SOLD
630whp 658wtq
2024 F-150 RCSB 5.0 4x4
waiting for tunes...
eLeSthree is offline   Reply With Quote
Old 06-25-2021, 08:11 AM   #3
Greenhornet2
Greenhornet2's Avatar
Drives: 2011 Camaro 2SS LS3 Whipple
Chirp can be lifter roller seized or damaged and wear on cam now. Sometimes you can get a chirp from the front crank seal. If you drove hard 2.5qts low it is a little concerning.
Greenhornet2 is offline   Reply With Quote
hard start, low oil, service stabilitrack
