Old 06-25-2021, 10:12 AM   #1
George-CZ
George-CZ's Avatar
Drives: 2010 2SS LS3 and 1978 STROKER 383
Pedders EP1200
I'm going to strengthen the rear axle mounting with Pedders bushings. I've read some procedures and I want to make sure I know what I'm doing.
So I pick up the car and support it in the back.
The jacks support subframe and diferencial.
I disconnect the shock absorbers from the arms and disconnect the stabilizer.
Then I release the subframe, remove the caps, and lower.
I put the inserts on and put subframe back on car.
That's all? Or did I forget something?
My life is a constant struggle with Camaro.
K&N CAI, Stainless Power longtubes, high flow cats, modified Ragazzon High Performance axle back, Soler Performance ported throttle body, Soler Performance throttle controller, RAM clutch adjuster, modified LS7 clutch kit, Tick Performance billet bearing support, Tick Performance remote bleeder, separate clutch reservoir, BMR trailing arms, BMR toe rods, Pedders Suspension cradle bushing inserts, Control Arm Bushings, Strut tower brace, oil catch can, Hurst T-handle shifter, 20mm wheel spacers, DBA brakes, QTP Cutouts, Dynosteve tune.
George-CZ is offline   Reply With Quote
Old 06-25-2021, 01:16 PM   #2
gtstorey
brake lines, muffler and driveshaft, emergency brake cable if removing subframe completely
Old 06-25-2021, 01:32 PM   #3
KillboyPowerhead
Drives: 2015 Z/22
If you're lowering the subframe just enough to fit the inserts (a few inches) you don't need to remove brake lines or the driveshaft; for exhaust you just need to pull out the mounts from the hangers at the mufflers and possibly the next ones further up (WD40 works great). There's also a rectangular brace about half way down the car which may need to be removed.
Removing those caps on the bottom of the subframe bushings is much easier said than done. An air hammer works great if you have one... Otherwise maybe a puller if you can fit one (can't remember how the factory bushings look exactly), like what you'd use for the crankshaft balancer. I did the solid bushings so I didn't need to take out/reuse the caps.
Subframe mount bolts are torqued to 165 ft/lbs. Loctite wouldn't be a bad idea.
When putting the shocks back on the lower control arms, jack up the arms so that they're at normal ride height before fully tightening (like you would when replacing any other suspension arm/bushing) so as to "time" the bushing properly. To know the ride height simply measure from the centre cap of the wheel to the bottom of the fender when the car's on the ground.
KillboyPowerhead is offline   Reply With Quote
Old 06-25-2021, 03:29 PM   #4
George-CZ
George-CZ's Avatar
I only need about 2-3 inches down.
I'll just put the inserts in the existing bushing.
Old 06-25-2021, 03:33 PM   #5
George-CZ
George-CZ's Avatar
That's exactly what I needed to know
I have an air hammer. I also saw how it is done.
I think this part of the work will not be a problem.
Thank you
Old 06-25-2021, 03:59 PM   #6
bayarea408
bayarea408's Avatar
Drives: T
i went from stock to those pedder inserts and now pegasus solid mounts. The inserts were noticeable and worked well for a few years. I added turbo and the back end once again became a area of concern. If you have plans to add alot more power i recommend go solid now. There isnt any added noise vibration just way more secure.
bayarea408 is offline   Reply With Quote
Old 06-25-2021, 04:17 PM   #7
George-CZ
George-CZ's Avatar
I am aware of all the variables associated with this step.
I read that these insoles are suitable for up to 500 horsepower.
I estimate I have about 440 on my wheels.
I do not intend to go higher with performance. The target of my other modifications will be the chassis. Not performance.
Old 06-25-2021, 07:03 PM   #8
1JEWLDSSRS
1JEWLDSSRS's Avatar
Drives: 2011 SS-RS
Awesome stuff my friend!! Nice mod. I went solid with the Pegasus mounts, and a 1pc driveshaft and man is she TIGHT!!
Old 07-07-2021, 04:30 PM   #9
George-CZ
George-CZ's Avatar
I'm done.
Thanks to KillboyPowerhead for help
I prepared everything, studied it beforehand and it went relatively smoothly.
The biggest problem is probably the caps.
The best part is that I bought a set of air tools a few years ago.
I unpacked it for the first time yesterday, and of course the air hammer didn't work
This probably pissed me off the most ...
Old 08-06-2021, 12:35 PM   #10
George-CZ
George-CZ's Avatar
To conclude this story, I was in geometry and the difference was so small that I dare say that no new adjustment is needed after installation.
