Old 06-26-2021, 04:24 AM   #1
CHRI55
Streetkingz_chri55
CHRI55's Avatar
Drives: 2012 2ss/rs
Bmr extreme sway bar
I currently have all the bells and whistles on the rear of my camaro without going drag suspension. Mostly adjustable stuff.. with that I have the bmr extreme sway bar and I have a few issues and concerns
1. What is everybody running theirs in to daily drive. I have mines on the middle setting and I'm hearing that's too tight for daily driving. (More of Weekend car now) but it ride rough. Don't know if it's from that or lowering 1in or whatever lol
2. I can't seem to keep the bolt in that holds the bushing in place. Currently emailing bmr to purchase a new bushing because I busted 1 lol
3. How hard it is to adjust it if I was to go to a low setting
Any advice and ideas are appreciated
I got all the suspension because I plan on boosting it soon. Currently cammed, 3.91, 4k stall
I do track and Mexico racing
CHRI55 is offline   Reply With Quote
Old 06-26-2021, 07:42 AM   #2
Ashen 6.2
Ashen 6.2's Avatar
Drives: 2014 Camaro Z/SS
Hi Chri55 - I have that same bar and run it on the hole farthest out for street driving and the only trip that I made to the strip since installing it. It does ride rougher for sure even on that setting and seemed to make a lot of popping noises at first.
I did have a bolt break and it nicked the aluminum bushing. When I got a new bolt for it I lengthened the rod end out quite a bit to reduce the sharp angles and that seems to have helped.
I haven't tried the other holes with it yet but it wouldn't be hard at all. Just need to mark and count any turns made with the rod end (if needed) so you know where to return it.
Roy
Name:  Screen Shot 2021-06-26 at 6.32.50 AM.jpg
Name:  Screen Shot 2021-06-26 at 6.33.01 AM.jpg
Tuned by Ben @BWTuned, GPI 416 w/GPI S/C Cam, GPI Ported Heads, Holley Dominator ECU, Mag Heartbeat, ZL1 Fuel Pump/DSX Aux Pump, NW 103 TB, FIC 1650's, Alky Meth, Rossler T400 w/t-brake, Circle D Converter, Kooks Headers, Viking Coil Overs & all the BMR Goodies in the rear, Zl1 3.23 Diff, DSS Axles, Wiles Racing Driveshaft, Hendrix Offset Diff Bushings, AFE Solid Subframe Bushings, 875HP/843TQ 5FDP
Ashen 6.2 is offline   Reply With Quote
Old 06-26-2021, 08:36 AM   #3
CHRI55
Streetkingz_chri55
CHRI55's Avatar
Drives: 2012 2ss/rs
I did have a bolt break and it nicked the aluminum bushing. When I got a new bolt for it I lengthened the rod end out quite a bit to reduce the sharp angles and that seems to have helped. 😁
Roy
Attachment 1072144
Attachment 1072145
Thx a lot. I thought the popping was coming from my 3.91 with the jre double clutch but I'm glad to know it's the suspension.. I move into my house Wednesday so now that I have a garage I'll get out there and change the bushing and see if that softest setting ease the rough ride a little... wonder why it pops like that
Old 06-28-2021, 06:46 AM   #4
Ashen 6.2
Ashen 6.2's Avatar
Sure thing! My assumption was that with the rod end all the way in its causing it to have extreme movement resulting in the slam/popping noise when its moving. again, thats an assumption. Anyways, what I did was count the number of turns the rod end will come out, put it back in all the way, the turned it out to the halfway point and tightened the nut up. I will check the measurement this afternoon or if I get a chance between calls today.
And congrats on the house & garage!
Old 06-28-2021, 08:29 PM   #5
Ashen 6.2
Ashen 6.2's Avatar
Ok, so its not quite halfway out but there is 8.5mm between the shoulder of the rod end and the nut.
Old 08-02-2021, 01:07 PM   #6
eLeSthree
Drives: 2011 Camaro SS 6sp
Is that lca compatible with the anti-roll bar linkage?
I have the other style bmr lca. See pic
2011 Camaro SS---SOLD
TMS Dart 427 FED M311s, ESS Tuning G4 Blower, DSX Triple FP Assembly, DSX FF, FIC1300, Mcleod RXT 1200HD, Edlebrock Pro Flo XT
1158whp 1017wtq.
2010 CTS-V A6 - "Stock" SOLD
630whp 658wtq
2024 F-150 RCSB 5.0 4x4
waiting for tunes...
eLeSthree is offline   Reply With Quote
Old 08-09-2021, 02:55 PM   #7
race21
Drives: 2012 Camaro ZL1
I'm just getting ready to install the heim joints and curious what lengths roughly you guys are running for the furthest (least stiffest) hole? Basically the center to to center length. Thanks.
race21 is offline   Reply With Quote
Old 08-09-2021, 06:56 PM   #8
eLeSthree
The linkage is adjustable but the bar moves up and down also. Just make sure u have a little preload on both sides evenly.
Im using the second hole. I had to tighten the linkage up a couple times after driving.
1158whp 1017wtq.
630whp 658wtq
Old 08-09-2021, 09:31 PM   #9
Ashen 6.2
Ashen 6.2's Avatar
Hi eLeSthree - Sorry, just saw your question. Yes. I called BMR before ordering that sway bar to make sure it would work with the BMR TCA-028 LCA’s.
I haven’t heard the popping noise in some time. Or I got used to it 🤷*♂️
