Old 06-27-2021, 02:06 PM   #1
jimmyducati
Drives: 01 SS Camaro
removing the oil pump... do you have to remove the motor from the car??
So im in the middle of a cam swap (changing out the BTR for a GP tuning) and have ran into a road block. I need to pull the oil pump to replace the LSA timing chain tensioner with the LS2 Damper AND install the C5R timing chain. In order to do any of that, the oil pan has to at a minimum, be lowered to access the pickup tube bolt.
I can find info on dropping a standard LS3 pan all day, but they don't have the big ass cooler on the driver side of the pan. Looking at the pan from the bottom, it seems nearly impossible to lower the pan to access that PIA bolt without just removing the motor entirely.
What is everyone doing to make accessing that pickup tube bolt achievable? can the pan be lowered without removing the oil cooler on the drivers side fo the pan?
jimmyducati is offline   Reply With Quote
Old 06-27-2021, 10:55 PM   #2
Risingson05
Risingson05's Avatar
Drives: 2015 zl1 m6
You either have to remove the motor or cutt the cross member . There’s a member here that you can buy the adapters to. Bolt back your crossmember together .
Risingson05 is offline   Reply With Quote
Old 06-28-2021, 12:09 AM   #3
fluxzl1
Drives: 2015 ZL1
just drop the oil pan enough to get at pick up tube bolt. pack some rags
in the pan opening so you dont lose the bolt in the pan...
just take your time its not that hard..
4 innovations twin pump fuel system,DSX flex sender,28% lower,1 7/8 dynatech headers,id 1050s,rotofab intake
LS 2 ported throttle body,elite catch can,JRE rough idle cam,active innerchiller, tuned by JRE....
fluxzl1 is offline   Reply With Quote
Old 06-28-2021, 08:39 AM   #4
beersngars
Drives: 2012 ZL1
It can be a pain in the ass, but you need to remove the small bolts that hold the wire harness that goes under the oil pan. Once that has been done, you will have the room required.
beersngars is offline   Reply With Quote
Old 06-28-2021, 09:42 AM   #5
RobZL1
fo'shizZL1
RobZL1's Avatar
Drives: 2017 ZL1
See posts 5, 7, 8, 9, 10: https://www.camaro5.com/forums/showthread.php?t=555094
2017 ZL1 M6 Black | Maggie 2650 // 103TB // Big Gulp // CSP LT's & Ultra Cats // BMR MM // BC Forged KL13
Mods being installed-
oil pump, cam, ported heads, dual in-tank, Goliath and XDI, corn, etc., etc.
RobZL1 is offline   Reply With Quote
Old 06-28-2021, 10:42 PM   #6
Crash76
Team 913
Drives: '14 ZL1, '15 Jeep GC, ‘22 Ram 2500
Dont cut the crossmember that is dumb…
Crash76 is offline   Reply With Quote
Old 06-28-2021, 11:15 PM   #7
Risingson05
Drives: 2015 zl1 m6
Well damn . Where the hell did I read about the cross member then . SMH my bad op .. yeah cutting the cross member is dumb then . My apologies .
Well I’m glad I haven’t started on mine then . This will make my life easier . Thanks for that guys ..
Old 06-30-2021, 02:04 AM   #8
morepowerjoe
morepowerjoe's Avatar
Drives: 2012 Chevrolet Camaro l99
DSS Pistons, Eagle ESP L19 Rods, ARP Head and Main Studs, TSP PRC CNC Ported Heads milled .030, Cometic .040 Head Gaskets, GPI SS3 VVT Camshaft, GM Racing Lifters, CHE Trunnions, Melling 10355HV Oil Pump, Cold Air Inductions CAI, Fast LSXR Intake Manifold, Nick Williams 103 TB, TSP Longtubes, ZL1 Fuel Pump, Mishimoto Radiator and Oil Cooler, 3600 Circle D Converter, Tru Cool 40k Tranny Cooler, Fluid Dynamics Balancer, EBC 3GD Rotors with EBC Bluestuff NDX Pads, Bilstein B6 Shocks / Struts with Eibach ZL1 Drop Springs
Build Thread https://www.camaro5.com/forums/showthread.php?t=609817
morepowerjoe is offline   Reply With Quote
