Go Back   Camaro5 Chevy Camaro Forum / Camaro ZL1, SS and V6 Forums - Camaro5.com > General Camaro Forums > Camaro ZL1 Forum - ZL1 Specific Topics > ZL1 Wheels/Tires
Old 06-29-2021, 03:58 PM   #1
harrington81
Drives: 2015 Camaro zl1
Uneven wear on right front tire.
Hi guys! My stock front Goodyear’s are wearing uneven. My front passenger tire is on the belt. It came like this stock. Is the alignment off or is the camber like that for the track? I’m putting on BFG all seasons when they’re available. My back tires did not wear like this.
Thanks!
harrington81 is offline   Reply With Quote
Old 06-29-2021, 04:22 PM   #2
gtstorey
Hard to tell from the picture, but is the entire tire wore pretty much smooth? I'm not sure that you can tell about uneven wear from a tire that wore out.
That said, a good alignment will likely make it handle better.
Old 06-29-2021, 05:18 PM   #3
SSammy
SSammy's Avatar
Drives: 2015 2SS A6 Commemorative Edition
I agree with gtstorey, at that point of worn out, there's probably no telling how a tire should wear.
If I were you, with the condition those tires are in, I'd get the new tires installed now and get the car aligned same day. While the car is on the rack, I'd check to see if there is any movement in the ball joints/linkages/bushings.
If the tires had a normal amount of tread left, and were showing this type of wear to the outside, I'd say it's one of the following...
-Too much toe-in
-Positive camber (tops leaning out)
-Zero camber or not enough negative camber for the amount of cornering
-Worn ball joints or bushings, causing camber and/or toe changes when cornering/accelerating/braking
SSammy is offline   Reply With Quote
Old 06-29-2021, 06:38 PM   #4
harrington81
Ok cool! Thanks guys for the advice. I’m gonna get an alignment done when we put the new tires on.
Old 06-29-2021, 07:19 PM   #5
Bigdumogre
Bigdumogre's Avatar
Drives: 2012 Camaro SS
Have them check the front end - looseness in a tie rod or control arm can also cause that. Then check alignment
2012 Camaro 2SS/RS - CSP Custom Cam 232/240 .615/.615 113 +3, Texas speed CNC heads, FTI billet triple disc converter, K&N cai, Katech ported TB, GPI Ported/rod modded manifold, Texas speed 1 7/8 headers, HFC, Flowmaster 2 chambers with x pipe, Mishimoto CC, MSD wires, Roto fab washer relocation, tru cool 40k trans cooler, apex scoop, Pedders extreme coil overs and much more!!
Bigdumogre is offline   Reply With Quote
Old 07-06-2021, 04:34 PM   #6
Provy
Provy's Avatar
Drives: 13 ZL1
Not to mention those tires are probably 6+ yrs old now.
Provy is offline   Reply With Quote
