Old 07-04-2021, 12:33 PM   #1
Batmanntexas
Batmanntexas's Avatar
Drives: 2012 Camaro SS (2SS)
HP Tuners VCM Scanner HELP!!
Hello all!!
I am trying to graph fuel pressure from an external sensor. I am using the MPVI Pro interface, and am successfully logging/graphing my WB02, as well as logging fuel pressure. I just can't get it to show in the chart/graph. Any suggestions?
745RWHP/634RWTQ on 93 @ 10psi
806/676 on E85 @ 10psi
Currently @15-16psi....
COTW 9/8/14
Batmanntexas is offline   Reply With Quote
Old 07-06-2021, 06:52 AM   #2
eLeSthree
Drives: 2011 Camaro SS 6sp
I'm just brainstorming here, but have you tried changing the chart Parameter to External Input/MPVI Pro/ MPVI A/D Input 3? I see you have the Transform parameter selected, and thats how my wideband is setup, but Im thinking maybe this type of gauge doesnt need to be transformed....? Just taking a stab in the dark here...
2011 Camaro SS---SOLD
TMS Dart 427 FED M311s, ESS Tuning G4 Blower, DSX Triple FP Assembly, DSX FF, FIC1300, Mcleod RXT 1200HD, Edlebrock Pro Flo XT
1158whp 1017wtq.
2010 CTS-V A6 - "Stock" SOLD
630whp 658wtq
2024 F-150 RCSB 5.0 4x4
waiting for tunes...
eLeSthree is offline   Reply With Quote
Old 07-06-2021, 03:10 PM   #3
joshnmn
2&THEHIT
joshnmn's Avatar
Drives: 5th Gen Camaro; 5th Gen Ram 3500
What I wanna see is the math involved for the hp value
If you’re willing, I’d be happy to see the layout
joshnmn is offline   Reply With Quote
Old 07-07-2021, 01:52 PM   #4
eLeSthree
You have to create a User Defined Math channel. Its RPM*Torque/5252
[50070.56]*[50108.127]/5252
You have to log the Engine Torque and RPM channels obviously. Then add that Math Channel (pid) to your charts layout.
Pretty old vid, but..
1158whp 1017wtq.
630whp 658wtq
Old 07-07-2021, 02:22 PM   #5
joshnmn
2&THEHIT
joshnmn's Avatar
Easy enough!
Didn’t realize torque was a measured variable. Thx
Old 07-07-2021, 11:16 PM   #6
Batmanntexas
I have tried that, and the sensor just outputs a linear voltage from .5VDC to 4.5VDC, so without the transform function I would just be logging a voltage....and I can't remember if I was able to get that to show up in the chart either....
-Scott
COTW 9/8/14
Old 07-08-2021, 06:18 AM   #7
eLeSthree
-Scott
Are you running the beta? Setup to auto install latest version? It seems like everything is setup right. Might wanna email support.
1158whp 1017wtq.
630whp 658wtq
