Old 07-06-2021, 09:22 PM   #1
Roc_1le
Drives: 2015 Camaro 2ss 1le
Electric power steering interminably working
so i just finished putting my built motor and huron speed single turbo kit back in my car.. been running for about 5 days. Yesterday while i was backing out of my drive way i noticed my power steering was gone and then came back within 10 seconds.. rest of day not an issue. today i went to look at a puppy im adopting and on the way doing 45 mph the power steering just went away and scared the shit out of me then came right back. then i noticed above 35 mph it happend more often.. especially when i hit bump.. prior to being boosted i never had an issue with my power steering and would like to fix it sooner than later.. any info would be great. Thank you!
Roc_1le is offline   Reply With Quote
Old 07-06-2021, 09:38 PM   #2
camguynj
camguynj's Avatar
Drives: '13 SS/RS LS3 BRM Cammed NPP
Check the ground
camguynj is offline   Reply With Quote
Old 07-07-2021, 12:38 PM   #3
HOJO
HOJO's Avatar
Drives: 2014 Camaro SS/RS 1LE 1967 Camaro
Yes, check all your grounds. Especially those associated with the electric steering. If it acts up more when hitting bumps I can't help to believe there is a ground issues. Good luck.
HOJO is offline   Reply With Quote
Old 07-07-2021, 03:33 PM   #4
larry_g
larry_g's Avatar
Drives: 2014 1SS/1LE
Besides grounds, also checked for pinched wires. I pinched mine to my steering rack when installing my engine.
powersteering
