Old 07-08-2021, 07:45 AM   #1
JANNETTYRACING
JANNETTYRACING's Avatar
Biggest overlooked problem with LSA
This is a huge problem from our perspective as we continue to see cars coming in with Air in the intercooler system.
People have been driving around for years with reduced power and never know it.
Air in the intercooler system can actually stop the pump from running as it monitors electrical load from pumping water, and will turn off as not to burn up the pump. (pump self protection)
Even if there is not enough air in the system to shut the pump down you will have high intake air temps which reduces Air density, which in turn reduces fuel delivery and ignition timing, so we have seen as much as 50 HP loss from this situation.
This simple tool from JRE makes filling and bleeding a dream.
Simply install this in place of the cap, To remove the cap turn the cap to straight up position, twist the cap 1/4 turn in either direction and pull straight up.
Then install the tool by simply inserting it, ( it will lock in same as cap) fill it with coolant start the car and let it run until no more bubbles are floating to the top of the coolant.
Often times you have to keep adding coolant as it gets drawn in in place of air.
Just keep the bottle about half full during the process.
Place a rag under the fitting, and remove the bottle capturing what you can with your finger.
Reinstall the cap and your done.
HORSEPOWER RESTORED.
https://jannettyracing.com/products/...cadillac-cts-v
www.jannettyracing.com
Celebrating 39 years Performance parts, Installation, Fabrication, Dyno tuning, Remote custom tuning, and alignments. 203-753-7223 Waterbury CT. 06705
email tedj@jannettyracing.com
Old 07-08-2021, 11:09 AM   #2
Burton5251
Burton5251's Avatar
Drives: 2013 Victory Red ZL1 M6 Coupe
Thumbs up
Honestly this is one of the best things I have purchased. Literally could not be easier to bled the system.
2013 M6 Victory Red Coupe | Roto-Fab Intake | Ceramic Coated Kooks 1 7/8” Headers | 2.55” Upper | 9.06” Lower | CSP Custom Grind Cam | DSX AUX & Flex Fuel Sensor | ID1050X | TR7IX | Taylor Wires | E2-X Ultra Catch Can |CSP Tuned W/ HPT | E85: 704/718 (SAE 5)| 93: 655/638 (SAE 5)
Burton5251 is offline   Reply With Quote
Old 07-08-2021, 11:10 AM   #3
Dega Man
Drives: ZL1
Does a reservoir eliminate this problem?
Dega Man is offline   Reply With Quote
Old 07-08-2021, 11:49 AM   #4
JB'sZL1
Drives: 2013 ZL1 and 2019 Ram Laramie
Yes, provided it is placed high, the reservoir will self-bleed.
JB'sZL1 is offline   Reply With Quote
Old 07-09-2021, 07:18 AM   #5
JANNETTYRACING
In my experience it does not because the water flow stirs air in to the water.
Also storing water in an hot engine compartment just adds heat to the water.
Keep it the way it is and just bleed it.
Ted.
Old 07-09-2021, 08:23 AM   #6
gtstorey
Where does this screw in? I'm wondering about getting it for my LSA supercharger on my 2010 SS (ADM Conversion).
Old 07-09-2021, 10:28 AM   #7
tartagliazl1
tartagliazl1's Avatar
Drives: 2013 zl1 vert
I looked into this and went to purchase but the cheapest shipping is $19 for a $35 dollar part that weighs 3oz. Shipped one state over. Why so high Ted?
22% lower/ 2.5 upper/ 2” headers/ cat delete/ x-pipe/ 2 gallon x tank/ 100-3 pump/ fic 1300/ dsx aux kit/ 103mm throttle body/ big gulp 5” intake/ meth kit/ prometh lid injection/FI interchiller/ 160* stat/ ngk-7/ msd wires/ elite catch can/ tsp cam/ Che trunnions/ ported supercharger/ 1/2” lid spacer/ cnc,milled ported heads/ brick mod/BMR toe and trailing arms/ 781hp 748 tq SAE @17.3lb on a loaded dyno.
tartagliazl1 is offline   Reply With Quote
Old 07-09-2021, 01:28 PM   #8
Bigtime53
Bigtime53's Avatar
Drives: 2013 ZL1
The piece that goes into the supercharger is that just like the piece that is already there? Then you just drill a hole in it and put the brass fitting into that and ad a couple o rings then get the other piece at any hardware store to screw onto the bottle? Looks like it to me. Am I wrong?
Bigtime53 is offline   Reply With Quote
Old 07-09-2021, 04:10 PM   #9
Little Walter
Drives: ZL1
I have two ZL's with heat exchangers and reservoirs and have never experienced the air problem, when I remove the cap from the reservoirs water is moving. I did experience this problem once prior to adding the reservoir and heat exchanger.
Little Walter is offline   Reply With Quote
Old 07-09-2021, 04:29 PM   #10
JB'sZL1
Right. I've had my Z for nearly five years. I placed a hex and D3 in, and have never had air entrapment, or overheating.
Old 07-16-2021, 09:24 AM   #11
JANNETTYRACING
OK is the water perfectly clear or does it look like soda.
Ted.
Old 07-17-2021, 01:41 PM   #12
Little Walter
Drives: ZL1
Ted.
It is flowing as clear as the water flowing in the radiator, definitely not even close to soda.
Old 07-17-2021, 11:24 PM   #13
silversleeper
Big Crow
silversleeper's Avatar
Drives: '13 ZL1
Does the coolant look like yellow Mountain Dew or Orange Fanta soda? The supercharger brick prefers zero calorie by the way.
I bought my ZL1 from a knowledgable Camaro guy but it was quite low on SC coolant and didn't have dexcool in it FWIW.
silversleeper is offline   Reply With Quote
Old 07-18-2021, 07:27 AM   #14
JANNETTYRACING
That is good but how much heat is being added to the coolant due to storing it under the hood Hottest place in the car.
Ted.
