Old 07-09-2021, 04:04 PM   #1
SS Mindset
Drives: 2011 Chevy Camaro ss
Gen5 motor swap
I need some help ladies and gents… if I have a wrecked 2010 Camaro ss and a 2015 Camaro ss SHELL(no motor and trans) will the motor and trans from the 2010 ss fit inside the 2015 ss plug and play…. The 2010 has everything under the hood… the 2015 ss has nothing under the hood. Was a clean motor and trans pull…. I need some help here b4 I start pulling the motor from the 2010
SS Mindset is offline   Reply With Quote
Old 07-09-2021, 04:07 PM   #2
bayarea408
bayarea408's Avatar
Drives: T
steering rack and radiator is different, but you wont have any problems sitting the motor and trans in another camaro unless its missing stuff.
bayarea408 is offline   Reply With Quote
Old 07-09-2021, 04:15 PM   #3
SS Mindset
If 2016 rack and radiator is intact. Am I good?
If I’m just pulling the motor and trans from the 2010 meaning wiring and everything and the 2015 rack is in tact. And I’m radiators is still in 2015. Then I should be good to go??? Clean plug and play swap??
Old 07-09-2021, 04:54 PM   #4
bayarea408
bayarea408's Avatar
Drives: T
I take all that back, i thought you were swapping a 10 ss into a new face lift gen 5. You going to shove gen 4 LSX into a LT 6th gen chassis, that's going to be fun. It will not be plug and play. You will have to really figure it out especially the fueling and how the transmission mounts in. Even the serp accessory style assembly up front will be different. Then you have to harness and do PCM stuff. lol Buy a finished camaro
Old 07-09-2021, 07:03 PM   #5
romcjr
romcjr's Avatar
Drives: Two 1984 Z28 / 2014 2SS/RS AGM L99
Glad you caught that . I was fixing to ask same question . How did it go from 2015 to 2016 ?
2014 2SS/RS AGM L99
CAI Intake
ELITE Catch Can
POWERSTOP Brakes (5/31/21)
romcjr is offline   Reply With Quote
Old 07-10-2021, 06:12 PM   #6
SS Mindset
2010 motor and trans inside of a 2015
It is a 2010 into a 2015. I typed 2016 in error….my apologies
Old 07-10-2021, 08:58 PM   #7
InFiD3ViL
InFiD3ViL's Avatar
So yeah, a mostly clean and easy plug and play swap. Are they the same trans? Auto to auto or manual to manual?
If it's an LS3 to L99 body swap or vice versa, you will also need an adapter for the crank sensor since they are different. L99 has a 5 pin crank sensor harness and the LS3 has a 3 pin, otherwise all the reset is identical in regards to wiring...aside from TCM of course.
But if the cars had the same trans originally, it should swap right over. Above it was mentioned that the 2015 has a different rack. It also has electric power steering, while the 2010 has full hydraulic. Not sure how this would affect the swap in relation to the harness.
Old 07-11-2021, 07:16 AM   #8
SS Mindset
Thank you for the info. I went to see the 2015…. I don’t think it’s worth the money. Too much work needed for the shell. Looks like I’m stuck with swapping the 2010 motor into a 2011 shell… I really do like that 2014/15 body style tho… if u guys know anyone who is selling a 2014/15 complete shell. Let me know. Prefer black but for the right deal I would consider a diff color. Oh yea…. Clean title
gen 5
