Water pump question
I have a whipple with a 10 rib setup and undrive pulley. Running 13lb of boost. I'm 99% sure I'm currently overspinning the water pump on long pulls and causing cavitation.
Has anyone switched to a different water pump. If so, what? Appreciate the help. |
Aside from an electric water pump, I don't think there are any other options. Have you looked into a smaller diameter water pump pulley by any chance? Might be cheaper than a replacement water pump anyways....
Just curious, what indications were you seeing that led you to the cavitation thought? -Scott |
#3 | |
Short, small runs it's fine. On a long (5 second+ WOT), if overheats after the run. If I burp the system, it's then fine. Open to other suggestions. |
![]() Drives: G8 Join Date: Mar 2012
Sounds like you need a separate serpentine system for the Whipple... Which I'm not sure exists for the Camaro
Sent from my Pixel 4 XL using Tapatalk |
![]() ![]() Drives: 2014 1SS/1LE Join Date: Nov 2015
Instead of the underdrive pulley, what about a stock size and a smaller blower pulley?
Not cheap but it would put the water pump back at stock rpm. Sent from my Pixel 5 using Tapatalk
#6 |
#7 |
![]() ![]() ![]() ![]() ![]() ![]() Drives: 2011 Camaro 2SS LS3 Whipple Join Date: May 2019
I was going to suggest this.
#8 |
I must be missing something here. OP stated that he is already running an underdrive pulley (1st post), which I assume he's referencing the harmonic damper. Does the 10-rib kit have a non-stock diameter WP pulley?
![]() The underdrive damper would already be turning the WP slower. Slower speeds wouldn't cause cavitation. |
#9 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2010 Camaro SS2,L99, LSA SC Join Date: Aug 2017
I think most of us reading this have assumed that he is actually running an overdrive to spin the SC faster. I don't know why he would want to underdrive with a SC.
#10 |
I wrote it wrong. Definitely an overdrive pulley.
#11 | |
![]() ![]() ![]() Drives: it changes Join Date: Nov 2010
You make no sense. And with an underdrive pulley, you will be spinning it even slower. Why do you think you are spinning it faster when pump speed is dictated entirely by crank pulley rpm/diameter and pump pulley diameter. And when nobody else has cavitation issues at any rpm on any other engine. |
#12 | |
What is normal temp for you, and what is "overheat" temp ? What stat ? And is the layout of the system as per factory, or has it been altered ? |
#13 |
Normal is <190. Tried both factory and 160 degree Stat. Overheat is north of 245 degrees. No change to layout of system, at all.
#14 |
I would be surprised if the very short fraction of time that you are at max rpms that you could have enough cavitation to be a problem with probably a 10% overdrive pulley. How high are you revving?
