![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2012 Chevrolet Camaro l99 Join Date: Aug 2020
1/4 mile estimate
Hey guys I'm thinking of going to the 1/4 mile drag strip and was wondering what do you think that I could run? I'm making 438rwhp and have the stock rear end and 305/20's BFG'S. All of my mods are in my signature. Thanks
DSS Pistons, Eagle ESP L19 Rods, ARP Head and Main Studs, TSP PRC CNC Ported Heads milled .030, Cometic .040 Head Gaskets, GPI SS3 VVT Camshaft, GM Racing Lifters, CHE Trunnions, Melling 10355HV Oil Pump, Cold Air Inductions CAI, Fast LSXR Intake Manifold, Nick Williams 103 TB, TSP Longtubes, ZL1 Fuel Pump, Mishimoto Radiator and Oil Cooler, 3600 Circle D Converter, Tru Cool 40k Tranny Cooler, Fluid Dynamics Balancer, EBC 3GD Rotors with EBC Bluestuff NDX Pads, Bilstein B6 Shocks / Struts with Eibach ZL1 Drop Springs
Build Thread https://www.camaro5.com/forums/showthread.php?t=609817 |
![]() ![]() ![]() ![]() ![]() Drives: Never just fly under the radar Join Date: Jul 2015
12.22
Old Skool |
I was hoping to be in the 11's but I guess that's not going to happen without drag radials you think?
![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 12 camaro ss, 72 chevelle, 91camaro Join Date: Dec 2013
Gonna need a tire and a converter to go 11s
2&THEHIT
Drives: 5th Gen Camaro; 5th Gen Ram 3500 Join Date: Mar 2018
I’d say 12.8. If you’re asking, probably 13’s til you figure it out. Street tires will definitely make it tough.
#6 |
How much time do you think that I could knock off with drag radials? And if I did go with drag radials do I have to worry about breaking an axle? I just replaced them with oem ones.
#7 |
Any rear suspension mods?
Tuned by Ben @BWTuned, GPI 416 w/GPI S/C Cam, GPI Ported Heads, Holley Dominator ECU, Mag Heartbeat, ZL1 Fuel Pump/DSX Aux Pump, NW 103 TB, FIC 1650's, Alky Meth, Rossler T400 w/t-brake, Circle D Converter, Kooks Headers, Viking Coil Overs & all the BMR Goodies in the rear, Zl1 3.23 Diff, DSS Axles, Wiles Racing Driveshaft, Hendrix Offset Diff Bushings, AFE Solid Subframe Bushings, 875HP/843TQ 5FDP |
#8 |
No not yet. But I am leaning towards changing out the rear sub frame bushings for the poly. What would you recommend?
#9 |
Evil Genius of Chevrolet
Drives: 2017 Z06, 2019 XTS, 2013 SS Join Date: Feb 2017
Toe rods, trailing arms are a must if you get drag radials.
My guess is mid to high 12's
GPI SS2 VVT cam, ECS Novi 1500 supercharger, Corsa Extreme, Detroit Speed and BMR suspension, Circle D triple disc, Melling oil pump, LS2 chain tensioner, ATI 10% UD, DSX E85 kit, High Energy coils, BTR springs, LS2 Lifter trays, Titanium retainers, hardened push rods, FIC 1000 injectors, ZL1 pump, Mighty Mouse catch can, AEM gauges, Tial BOV, Richmond 3.91 gears, Custom gauge bezels, Speed Engineering headers, Stainless Works HF cats, DSX Aux pump, 710rwhp on E85.
#10 |
Should I do the toe rods and trailing arms instead of the bushings?
#11 |
waiting at the tree
Drives: SIM 2010 2SS/RS A6 Join Date: Apr 2013
I agree.
The TQ Converter is worth 4-5 tenths with a good drag radial. Wheel hop is what breaks axles.
2010 2SS/RS A6 Just a few bolt-ons and appearance doo dads
#12 |
I did all 3 and have no wheel hop. I also did delrin control arm bushings.
#13 |
So would you point me in the right direction of best brands and parts needed for toe rods, trailing arms, control arm bushings, and subframe bushings? Thanks guys.
#14 |
I have BMR trailing arms and Toe rods. I put in Detroit speed cradle bushings. And I believe the delrin control arm bushings were GM. But lots of good brands out there to pick from. Do some research.
