Old 07-14-2021, 03:19 AM   #1
KingDun34
KingDun34's Avatar
Drives: 2013 Camaro 2SS LS3
Post NA L99 build (Help!!!)
So last time I posted on here I said I had a ls3 engine, however I came to the realization that I actually had the l99 engine due to is being a automatic. Now I know how dumb that sounds because the ls3 was for the manual, at the time I purchased the car it had the ls3 badging plus I was a HEAVY mopar guy and was not sooo knowledgeable about Chevy motors BUT I am learning. I say all of that to say/ask what are some reliable(daily driver) NA l99 Setups? Please drop some mod list!! Please remember I do want to stay NA but I will go forced induction down the line but not right now
I currently only have a Cai & and a mid muffler delete. I plan on getting LongTube headers from MadHatter garage, a SS1 VVT GPI cam , a ported throttle body and a tune. Am I on the right path?
I want to be able to beat scats but continue to keep the car’s reliability. I’m not building a race car.
As always I appreciate the feedback and no negativity I’m learning along the way🤝
KingDun34 is offline   Reply With Quote
Old 07-14-2021, 05:27 AM   #2
Bigdumogre
Bigdumogre's Avatar
Drives: 2012 Camaro SS
L99 and LS3 are pretty much the same so it’s no real big deal to call it a ls3. Some people get upset but who gives a fuk.
I have full bolt ons in my sig and beat scat packs - long tubes and tune go a long way in these cars. Also the rod mod intake by gpi is great and cheap if you send them back your old manifold.
2012 Camaro 2SS/RS - CSP Custom Cam 232/240 .615/.615 113 +3, Texas speed CNC heads, FTI billet triple disc converter, K&N cai, Katech ported TB, GPI Ported/rod modded manifold, Texas speed 1 7/8 headers, HFC, Flowmaster 2 chambers with x pipe, Mishimoto CC, MSD wires, Roto fab washer relocation, tru cool 40k trans cooler, apex scoop, Pedders extreme coil overs and much more!!
Bigdumogre is offline   Reply With Quote
Old 07-14-2021, 07:27 AM   #3
Badbubba
GrINned & JUICEd
Badbubba's Avatar
Drives: 15STI, 10Expy, 10 2SS/RS M6, 47KB1
What mods were done to your car before you purchased it? The previous owner could have done a "LS3 conversion" to the L99. Which makes it similar to a LS3.
GPI SS3 Cam & stuff,N.O. Plate(dedicated fuel tank,progressive,fuel hose upgrade,remote opener,heater,console switches),LNC2000,CTAP,ARH 1 7/8" LTs/gutted cats/X pipe/mufflers,Jet Hot coated LTs,GPI HPT Tune,CAI, Scoop,Rx Catch Can,Gates heater hose relocation, Remote clutch & auto brake res,Metco loop,Momentum Tunnel Brace,TSW Nurb 18",555 & 05,Pfadt trailing arms & toe rods,Autometer WB,Fesler Pillar Pod,LED strips (int),Lloyds floor & trunk mats,LED DRL/front turn & license plate,DRL harness,VLEDs tail lights,Plasticoat Bowties. Ord: Oct 5, 2009 Rec: Nov 19, 2009 13.17@112.6 stock
Badbubba is offline   Reply With Quote
Old 07-14-2021, 07:41 AM   #4
LCPLPunk
USA-1
LCPLPunk's Avatar
Drives: 2010 Camaro SS L99
On the L99, if you don't have an aftermarket higher stall converter, you are doing it wrong!
With that cam, I'd run either a 3200 or 3600, it's up to you.
"A Camaro in the garage is safe, but that's not what Camaros are built for..."
R2C CAI / Apex Scoop / VMAX Ported TB / Speed Engineering LTHs / X-pipe / GPI port/rod-mod intake manifold / Circle D 3200 278mm Converter / 3.91 gears / DynoSteve tuned / 1LE Shocks/Struts/Toe Links / ZL1 Rear Sway Bar / Z/28 Trailing arms / Prothane Radius Arm & Subframe Bushings / BMR UCA Bracket, Steering rack bushing / B&M Tranny Cooler / RX Catch Can / Jannetty Tranny Dipstick / 2012+ Heater Hose / 2013+ Rearview Mirror / Fuel rail flip / Drake shifter / Oil Cooler Delete
LCPLPunk is offline   Reply With Quote
Old 07-14-2021, 08:24 AM   #5
TheFlyingBananaSS
Evil Genius of Chevrolet
TheFlyingBananaSS's Avatar
Drives: 2017 Z06, 2019 XTS, 2013 SS
Take a look at my signature. You could do everything except the supercharger and probably get over 500whp. Then you can go FI down the road. Keeping VVT is up to you but I am thankful I kept it. I've been gapping supras, hellcats, M8, M6, corvettes, etc.....
GPI SS2 VVT cam, ECS Novi 1500 supercharger, Corsa Extreme, Detroit Speed and BMR suspension, Circle D triple disc, Melling oil pump, LS2 chain tensioner, ATI 10% UD, DSX E85 kit, High Energy coils, BTR springs, LS2 Lifter trays, Titanium retainers, hardened push rods, FIC 1000 injectors, ZL1 pump, Mighty Mouse catch can, AEM gauges, Tial BOV, Richmond 3.91 gears, Custom gauge bezels, Speed Engineering headers, Stainless Works HF cats, DSX Aux pump, 710rwhp on E85.
TheFlyingBananaSS is offline   Reply With Quote
Old 07-14-2021, 11:52 AM   #6
gunchamp
gunchamp's Avatar
Drives: 15 Camaro SS
Same here. I went NA first and the car was a blast. Forced induction opens up a new world that you didnt know existed. These cars are easy to make stupid fast. Just takes a bit of coin. I went the other way and bailed the VVT. Honestly, I;m the keep is simple stupid type of guy, so less moving parts are a good thing IMO. Less stuff to cause issues. Keeping VVT or deleting is fine. Not reall ya bad decision either way
15 Camaro SS- GPI max top end, ESS Vortech V3 9psi, ID 1050s, ZL1 pump, JMS bap, Long tubes, Corsa extreme, Circle D pro 5C, 391 rear, DSS carbon drive shaft, poly cradle bushings, tuned by Ted Jannetty and much much more
gunchamp is offline   Reply With Quote
Old 07-14-2021, 12:01 PM   #7
TheFlyingBananaSS
You ain't kidding either. My son drove my camaro, I drove my Z06.... he blew my doors off LOL.
Old 07-14-2021, 08:43 PM   #8
Modernmusclecar
Modernmusclecar's Avatar
Drives: 2011 Camaro SS
500 whp is difficult to reach in an l99. Im pretty much maxed out on my mods. I dont have an intake or rodmod but i doubt those would make up 45 whp.
EPS CUSTOM GRIND CAM....K@N CAI....VMAX PTB.....FRANKENSTEIN STAGE 2 HEADS ...1 7/8 STAINLESS POWER CATTED LONGTUBE HEADERS...CORSA XTREME 3 INCH CATBACK.....CIRCLE D 3800 Pro Series stall...391 gears.....Ported/modded GPI intake .Forgestar drag pack with Mickey Thompson ET street drag radials AGP PERFORMANCE DYNO TUNED. 463 WHP 428 FTLBS TORQUE.
Modernmusclecar is offline   Reply With Quote
Old 07-14-2021, 09:34 PM   #9
InFiD3ViL
InFiD3ViL's Avatar
I'm likely in the same boat. I have an LS3 in mine now, but I am still rocking that 6L80e. I may have a couple extra ponies freed up due to the flattop pistons, very slightly milled heads (I calculated I should be at 11:1), and the ability to rev a bit higher due to the hollow intake valves. But it is still bolted to that power sucking auto trans.
Oh well, what we lose in rwhp we gain in shift speed, right? If I keep repeating that over and over I might even believe it someday!
Old 07-14-2021, 10:49 PM   #10
Aqua Blue RS/SS
Aqua Blue RS/SS's Avatar
Drives: ABM #93
Not sure what planet you live on, I read somewhere online that the rod mod is worth over a 100HP to the wheels
Yea us auto guys are at a bit of a disadvantage power wise; the 6l80 is a power sucker for sure. That said the auto still has some pretty decent positives, I wouldn’t mind an M6 SS along side my A6 SS one day.
ABM #2399 2SS/RS:SOLD
ABM #93 2SS/RS Black Rally stripes, Titanium Interior 4,000 miles: GM GFX side skirts and diffuser waiting on paint, GM dovetail, GM heritage, RPI ZL1 style splitter.
‘87 IROC-Z Iroc blue. all original unmolested with 50K miles.
Aqua Blue RS/SS is offline   Reply With Quote
Old 07-15-2021, 04:02 AM   #11
Chris49066SS
Chris49066SS's Avatar
Drives: 2010 SS L99
Still rocking the solid L99 valves for right now to 7600 rpm
But you and Aqua have to admit, the 1st gear in the auto is nice. When you pair it with 3.91s, a sticky tire and some weight reduction, well, things get spicy haha
Previous PB:11.079 @ 122.99mph.. New setup time: TBD
The 11.079 pass: https://youtu.be/pz27Zq54t_E
Build thread - www.camaro5.com/forums/showthread.php?t=555371
Chris49066SS is offline   Reply With Quote
Old 07-15-2021, 11:37 AM   #12
Aqua Blue RS/SS
Drives: ABM #93
Hell yea it is! Even in stock form it pulls pretty hard out of the hole all things considered. I can’t friggin wait for boost.
Old 07-15-2021, 11:41 AM   #13
TheFlyingBananaSS
When mine hits second I usually jump ahead a good car length of most people. 2nd gear is a monster with boost. First is almost like a gear to help it start rolling. It really only stays in first for about one second.
Old 07-15-2021, 02:09 PM   #14
Modernmusclecar
Haha...well damn a better pony up the dough.
2ss, build advice, l99 engine, ls3 5thgen
