Throttle Junkie
Drives: 2015 Camaro 2SS Join Date: Dec 2016
Installing wiring thru firewall advice
I will be picking my ‘15 ss up tomorrow after a pro charger install and tune
The shop will be unable to install the boost tubing or the wide band O2 sensor to my gauge installed in the left side vent. My question is where would I best run through my firewall to end up in this area. I can have the shop do it, but i think I’ll need to schedule time, wait and drop the car off again. I am pretty confident this is something i can handle, but i I’ve never worked on this car yet aside from running power to speakers in the trunk Any advice would be appreciated. TIA Aaron |
![]() ![]() Drives: T Join Date: Mar 2015
this is super easy. Take your hand and feel around the brake booster area there is a rubber gromet you can take out punch holes and run lines. I run all my boost controller and wide band stuff through it very clean and no hard edging to damage the wire. Then pop off the side panel of the dash on the driver side and there is the fuse box to tap. Best of luck.
#3 | |
![]() ![]() ![]() Drives: Camaro Convertible 2014 1LT Join Date: May 2019
Anyway, as bayarea408 said, the grommet is right there and you can carefully poke a hole in it for your wire(s) to go through and not worry about shorting out. Once you get the wire through, you may have to get on the floor under the steering wheel and pull back the carpet behind the pedals, flash a light up to the inside of the firewall and you should see the cable you are running sticking out and yes, it's close to the fuse box.
Yep! Drivers side firewall corner. Hard to see but can feel a rubber plug. Lots of my stuff goes through there.
Throttle Junkie
Thanks for the responses Bayarea and joe. Going to tackle this over the weekend. I’ll let you know how it goes
#6 |
Banned
Drives: 2010 LS Join Date: Feb 2021
Ran mine out the same grommet as the battery to front power cable passes through
into the engine compartment. |
