Old 07-15-2021, 11:08 AM   #1
2SSVert2014
Drives: 2014 2SS Convertible Black w/ Gray
Question How to fix headlight halo
Hello,
So I own a 2014 Camaro 2SS Convertible, which I bought used about 2-3 years ago. It only has 34k miles on it (17k of which I have put on it), and the passenger side headlight has two led segments in the halo out. Is there anyway to fix this without having to replace the whole headlight assembly (as those are very expensive)?
Thanks,
Robert
2SSVert2014 is offline   Reply With Quote
Old 07-16-2021, 12:48 PM   #2
tmaleck
tmaleck's Avatar
Drives: Replacement 2SS 'Vert 67 Cutlass
My thought is that it may be a cold solder connection. The headlight would have to come apart, I think most use the oven technique. Is there a reasonably priced used one available?
tmaleck is offline   Reply With Quote
Old 07-16-2021, 03:01 PM   #3
Nokke
Drives: Camaro SS 2010
Try to find videos for opening headlight.. there you can see what you can do just opening hatches behind the headlight. At least on 2010 headlight you can change led from hatch under the light, but it is little bit different.....
Nokke is offline   Reply With Quote
Old 07-30-2021, 07:04 PM   #4
2SSVert2014
I will look around, thanks.
halo, headlight
