Cranking compression variances
So, during my trip to Camaro Fest, I felt the car was down on power a little bit. I drove it back home and let it sit for a few days before I got around to looking at it.
Today, I performed a compression check and got the following readings: CYL #1 = 190psi CYL #2 = 175psi CYL #3 = 200psi CYL #4 = 185psi CYL #5 = 175psi CYL #6 = 175psi CYL #7 = 170psi CYL #8 = 200psi Engine specs are: Stock rotating assembly (4.065" x 3.622") Custom Cam (227/243 115LSA 110 ICL) ported & decked stock heads (can't remember how much was cut, maybe .020") LS9 head gaskets Using some online calculators (using stock chamber volume, 70cc), the calculator indicated I should have around 190psi gauge pressure, with about 210psi actual cranking pressure. Other than 'feeling' down on power, the car doesn't exhibit any symptoms, i.e. doesn't smoke, consume oil, run hot, etc. What do you guys think? -Scott |
Did you try doing the gimp mode (low octane) reset? Pull these fuses for 5 to 10 minutes...
What WILL happen with the fuse pull is your volatile memory will be reset. This includes long term + short term fuel trims, knock retard, etc... but what is important in this case is the little parameter that determines which spark table to use will reset...meaning if you were running from the low octane tables before (safe + slow mode), after the fuse pull it will force the computer to try the high octane table again. |
![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2012 Chevrolet Camaro l99 Join Date: Aug 2020
Idk. 200-175 psi is a pretty big variance. But I think your ok for now but if it gets any worse I would start looking towards a rebuild possibly. How many miles do you have?
DSS Pistons, Eagle ESP L19 Rods, ARP Head and Main Studs, TSP PRC CNC Ported Heads milled .030, Cometic .040 Head Gaskets, GPI SS3 VVT Camshaft, GM Racing Lifters, CHE Trunnions, Melling 10355HV Oil Pump, Cold Air Inductions CAI, Fast LSXR Intake Manifold, Nick Williams 103 TB, TSP Longtubes, ZL1 Fuel Pump, Mishimoto Radiator and Oil Cooler, 3600 Circle D Converter, Tru Cool 40k Tranny Cooler, Fluid Dynamics Balancer, EBC 3GD Rotors with EBC Bluestuff NDX Pads, Bilstein B6 Shocks / Struts with Eibach ZL1 Drop Springs
Build Thread https://www.camaro5.com/forums/showthread.php?t=609817 |
![]() ![]() Drives: 2014 1SS/1LE Join Date: Nov 2015
General rule of thumb is +/- 10% so you are close to within variance. Squirt a little oil in the low cylinder and test it again. If there is a noticable increase, it's likely the rings.
![]() Drives: 2014 Camaro 2SS Join Date: Feb 2015
Watch the first compression pulse on the gauge. It should jump immediately over 90 psi on that first pulse. That would tell you your valves have a good seal. If it doesnt, then your valves arent sealing as well as they could. Squirting oil in there as mentioned, will bring the overall compression up if the rings are worn.
#6 |
YouTube-Car Nation Videos
Drives: 2010 Chevrolet Camaro Join Date: Nov 2019
It sounds like the rings aren’t getting a good seal. Try what the guy above said with the oil and run the test again. Might be time for a rebuild.
#7 | |
-Scott |
#8 |
I'm sitting around 80K miles. Yeah, I'm leaning towards the rebuild option.
#9 |
Excuse my ignorance here.... but what does octane, gimp mode and fuse pulls have anything to do with a compression test?
#10 | |
Thanks, Scott |
#11 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: ABM #93 Join Date: Oct 2018
You might try a leak down test. That will help diagnose things a lot better. It could be as simple as a couple leaky valve seats. I build engines for a living and this is what I would do next in your shoes.
ABM #2399 2SS/RS:SOLD
ABM #93 2SS/RS Black Rally stripes, Titanium Interior 4,000 miles: GM GFX side skirts and diffuser waiting on paint, GM dovetail, GM heritage, RPI ZL1 style splitter. ‘87 IROC-Z Iroc blue. all original unmolested with 50K miles. |
#12 |
Do you do a lot of racing or just around town short pulls?
#13 |
GrINned & JUICEd
Drives: 15STI, 10Expy, 10 2SS/RS M6, 47KB1 Join Date: Nov 2009
Did you open your throttle body and bypass valve completely for the compression test? As well as disable the fuel injectors? I've read that if you hold the gas pedal down, it disables the injectors. Sort of like a flooded condition. Never did it though. I'd pull the plugs at the injectors.
GPI SS3 Cam & stuff,N.O. Plate(dedicated fuel tank,progressive,fuel hose upgrade,remote opener,heater,console switches),LNC2000,CTAP,ARH 1 7/8" LTs/gutted cats/X pipe/mufflers,Jet Hot coated LTs,GPI HPT Tune,CAI, Scoop,Rx Catch Can,Gates heater hose relocation, Remote clutch & auto brake res,Metco loop,Momentum Tunnel Brace,TSW Nurb 18",555 & 05,Pfadt trailing arms & toe rods,Autometer WB,Fesler Pillar Pod,LED strips (int),Lloyds floor & trunk mats,LED DRL/front turn & license plate,DRL harness,VLEDs tail lights,Plasticoat Bowties. Ord: Oct 5, 2009 Rec: Nov 19, 2009 13.17@112.6 stock
#14 |
![]() Drives: 2010 camaro 2SS/RS M6 Join Date: Sep 2014
I'm not saying it's good or bad but that's the same numbers I had on my car sbe 30k miles. When I done the leakdown the cylinders with lower compression did show a higher rate but were still within acceptable ranges.
I do think it's the exhaust valves on those cylinders. We'll hopefully see this winter when I do the heads
Texas speed F-35 cam, rollmaster timing set, melling hp pump, ls2 chain damper, fluid damper 25% under drive, Che rocker bushings, tsp .660 lift valve springs, BBK CAI Amzoil filter with Phastek ww relocation and scoop, Gmpp axle back, Speed engineering 1 7/8" LT's no cats, Peak speed shop ported tb, NGK tr6, MSD wires, Amsoil Zrod wix, heritage grill, 1.25" BMR springs, MRR 228, Nitto Nt05,dyno tuned by complete street performance, elite eng catch can, clean side separator, Hurst shifter, Zl1 addon wickerbill
