Old 07-21-2021, 10:27 PM   #1
LT1Zob
LT1Zob's Avatar
Drives: 23 LT1 / 19 Z06 / after 6 5th gens
Vitesse TC Longterm
Let me start by saying I was never a fan of, nor purchased a throttle controller because I never wanted to mess with a drive by wire system. If I wanted more power without dead spots, I got a tune, ported my TB, hell, I had my supercharger ported too while I was at it. Always thought TCs were nothing more than placebo BS.
Fast forward to today. A couple weeks back I picked up a 12 RS from the original owner. Incredibly well maintained and loved car. It has a CAI, Vmax TB, Borla, MGW short-throw and the 2 button (original design) Vitesse throttle controller. The reponse on 5 feels pretty good, not going to lie. I'm fully aware that it provides nothing other than a quicker throttle response, but I don't hate it. Actually thinking of keeping it on the car.
This brings up the question. I will be driving this car often and long trips with the wife. Basically, no snow or salt on the ground = I'm enjoying this car. So with that in mind, can you guys share your longterm experience with the Vitesse? CELs? ECU issues that developed over time? Limp mode? Or everything is just fine? It's now been years since this thing came out, so there should be some good, longterm data out there. Thanks in advance (and no YouTube vid links please, I've already watched those). I'm interested in your experience.
"Make yourself sheep and the wolves will eat you"
LT1Zob is offline   Reply With Quote
Old 07-22-2021, 10:31 AM   #2
DRC69
DRC69's Avatar
Drives: 2011 2LT/RS
Hi,
I have the VTC (2 button) setup to on #5. But I think it doesn't play-well with my tune.
I like it but. I haven't had any issues.
I'm planning on buying a JMS PedalMax to see if it will be a-little smoother.
Will see.
DRC69 is offline   Reply With Quote
Old 07-22-2021, 11:54 AM   #3
SSFury
My Road Rage is Legendary
SSFury's Avatar
Drives: 2011 IOM 2SS/RS "Fury"
I ran mine for around 6 years with no issues. Usually left it set around 5. The last six months or so, I started playing racecar a bit more, setting it to 7, and sometimes 9. Within 6 months of really getting on it, it started malfunctioning and kicking the car into limp mode. I had to remove it.
I now have a tune, and a tune does NOT do what that did. I fully plan on getting another throttle controller, but next time it will be a Pedal Commander.
Every Time You Buckle Up In That Car, Tonight Might Be The Night That You Die.
SSFury is offline   Reply With Quote
Old 07-22-2021, 01:32 PM   #4
crazy4camaro
Drives: 2012 RSLT,1979 Trans Am
I had and enjoyed VTC for a couple years , then for unknown reason started throwing limp mode, stabitrak codes removed it and replaced after about a year with pedal commander
crazy4camaro is offline   Reply With Quote
Old 07-22-2021, 03:34 PM   #5
Rainbow1616
Rainbow1616's Avatar
Drives: 2011 Inferno Orange Camaro 2SS/RS
I have had mine on for about 7 or 8 years. I do have a tune and I have had no issues at all.
I typically leave it set at 7
Rainbow1616 is offline   Reply With Quote
Old 07-22-2021, 04:59 PM   #6
LT1Zob
LT1Zob's Avatar
Thank you everyone for your input. I’ll leave it in until/if I have an issue. Then I’ll reconsider my options.
Old 07-22-2021, 05:30 PM   #7
spyderbuddy
on #10 for the last 8 years, you just get use to it. And make a Kick on a RS when set to Sport Mode
Old 07-22-2021, 07:47 PM   #8
KillboyPowerhead
Drives: 2015 Z/22
Had mine for ~6 years; the only issue I had was when I tapped the throttle a couple of times in quick succession and got a code (reduced power, etc.) related to the throttle position sensor not meeting command (not surprising considering what the throttle controller does). Typically keep it on #5, and even with a tune (Overkill) #5 seems much more responsive. As mentioned, worst case use it for now and if it gives you regular issues then stop using it.
KillboyPowerhead is offline   Reply With Quote
Old 07-22-2021, 10:20 PM   #9
InFiD3ViL
InFiD3ViL's Avatar
Had mine since early 2017. Not a single problem with it. I have had it under multiple tunes and many different mods. I did have to lower the settings once I got a ported throttle body. I keep it on SP6 now. Anything higher and it's just ridiculous and makes it impossible to take off from a stop.
Its so weird how some cars it works great and other cars it throws codes like crazy.
Old 07-22-2021, 10:51 PM   #10
camguynj
camguynj's Avatar
Drives: '13 SS/RS LS3 BRM Cammed NPP
Got mine Oct '14 when it first came out, so I've had it now 6 1/2ys with no problems. I try to follow all VTC threads so I'm very familiar with all the reported issues. They seem to be caused mostly by 1) improper install calibration or 2) changing SP settings while driving. Also more automatics than manuals seem to have problems, and what he said above ^^^^.
IMO the pedal sensor seems to like a stable setting. I keep it on SP5 ...like Goldylocks said "just right". SP6 or above with my 3:91 rear and PTB is like holy sheets I also added a Dyno Steve remote tune about 1k mi ago with no problems.
camguynj is online now   Reply With Quote
Old 07-22-2021, 11:07 PM   #11
LT1Zob
LT1Zob's Avatar
Thanks for mentioning this. Now it's coming back to me. I remember following these threads years ago and several people specifically warning about not playing with the settings while driving.
Otherwise, thanks everyone. Decision made, it stays until it gives me a reason to throw it away.
Old 07-22-2021, 11:48 PM   #12
Danial
Danial's Avatar
Drives: 2013 SS/RS, 2015 Camaro SS/RS Vert
If you tweak regularly these things have a tendency to go into limp mode but if you set it and leave it alone, you should be relatively ok. I have one. I can't even give it away. No one wants it. I took it off my car about 3 months after I put it on. One limp mode is one too many.
Danial is offline   Reply With Quote
Old 07-26-2021, 08:34 PM   #13
GetSmart
GetSmart's Avatar
Drives: 2013 Black SS
Had mine on for about 7 years. Never had a problem with it. I always fiddle with it while driving and still runs good.
Rotofab CAI, VMAX PTB, Borla S axle-back, Dynatech SuperMaxx 1 7/8" headers/HF cats, No weeds exhaust diverters, Apex air scoop & catch can, Rohana wheels, MPD1 Z-Force Hood, BTR Stage 3 cam, Vitesse Throttle Controller, etc...
GetSmart is offline   Reply With Quote
Old 08-07-2021, 11:00 PM   #14
Jazzzed
Jazzzed's Avatar
Drives: 2015 Camaro LT
5 years and 50,000 miles with no issues.
Jazzzed is offline   Reply With Quote
