Old 07-27-2021, 02:57 PM   #1
BatmaroBeauty
BOOST OR BUST
BatmaroBeauty's Avatar
Drives: 2010 Camaro 1LT
ISO/WTB A-Pillar Retainer Clip (UPDATE: FOUND)
Update: Part found and replaced!
[top]Original Post
Hey C5 Family,
I’m reaching out to you all in hopes that someone in this huge community can help me out. I sent my triple pod a-pillar to be reworked for the rear pod housings to be enlarged for easier accessibility and when they cut the back openings they also accidentally cut the safety strap off the retainer clip that secures the trim into place on the pillar.
This is what the part is supposed to look like:
I ordered what appeared to be this clip P/N 11611451 for my 2010 Camaro from GM Parts Store but what they sent me was definitely not the correct piece I needed. I received some sort of 12 inch metal rod with a 90° bend on one end and threading on the other. No idea what it’s used for. I emailed them back with an inquiry but no response.
I even called several local junk yards to see if they had any 2010-11 Camaro's on their lot that I could scavenge off but no luck. One place in NJ said it would cost me $48 shipped which seems outrageously overpriced for a small plastic clip.
I was hoping someone on here has a spare of the correct A-Pillar Retainer Clips laying around that they didn’t need and would be willing to send me? Please let me know, TYIA!
Batmaro=The Bane of My Existence ⠀⠀⠀⠀⠀ ⠀ ⠀⠀⠀⠀⠀⠀ ⠀ ⠀ ⠀⠀⠀ ⬋LIKE AND FOLLOW THE BUILD ON INSTAGRAM⬊
BUILD STATUS: LOADING BOOST . . .
BatmaroBeauty is offline   Reply With Quote
Old 07-27-2021, 10:31 PM   #2
Leo72793
Drives: 2011 2SS/RS
I called my dealer. provided my vin and the ones ordered were the newest revision. $11 each or something.
•2011 Camaro SS 2SS/RS A6
•MRR M017 1le Replica Wheels
•Vararam Ram Air Intake
•Speed Engineering Longtube Headers w/ Magnaflow HF Cats
•Bo White PnP Stage 2 TB
•GPI SS2 VVT Cam w Cometic thin gaskets 10.69 compression
•Xpipe w/ Res Delete and NPP Exhaust
•Tuned By Anonymous Calibrations
•Gen5DIY Mylink Conversion W/ Backup Cam
•Morel 3 way custom speakers, Infinity 860w Subwoofers in trunk baffle
•Helix P6 6ch amp w/ 8ch DSP and P1 Sub amp
Leo72793 is offline   Reply With Quote
Old 07-28-2021, 11:30 AM   #3
CamaroCracka
CamaroCracka's Avatar
Drives: 2010 Turbo LS3
new ones are better too.
Old 07-29-2021, 11:47 AM   #4
BatmaroBeauty
BOOST OR BUST
Thumbs up Update: Found (7/29/2021)
Thanks to all who contributed, I found and replaced the OEM retainer clip.
