Old 07-30-2021, 09:21 PM   #1
theflea42
#938 of 1524
Drives: 2013 Hot Wheels Edition Camaro
This will make you cry
I went to Long John Silver's to get something to eat this evening, and went through the drive thru. The drive thru is shaped like a Z, but the line in the middle is straight and not leaning like a normal Z. Each bend is dang near 90 degrees and not a lot of room to navigate. You pull in to order, then make a left hand turn 90 degrees to get to the window to pay and pick up the food, then make a right hand 90 degree turn to get out. Well, I hit the dang curb!
Now I've gotta get a new tire, and fix the rim.
theflea42 is offline   Reply With Quote
Old 07-30-2021, 09:26 PM   #2
Shan
Shan's Avatar
Drives: 2013 ls Camaro
Geez could you just go over the rim with another RimBlade protecor & how long do the blades last I was thinking about getting some
Shan is offline   Reply With Quote
Old 07-30-2021, 09:31 PM   #3
MarkNJ
MarkNJ's Avatar
Drives: 2015 2SS Commemorative Edition
That's too bad. Maybe a reason to get 275's and 315's now?
MarkNJ is offline   Reply With Quote
Old 07-30-2021, 09:36 PM   #4
Shan
Shan's Avatar
Or you could just glue that rubber piece back on since it’s not that deep that’s what I did
Old 07-30-2021, 10:16 PM   #5
davidscamaro
davidscamaro's Avatar
Drives: 2010 SS/RS M6 BIG cam
Tire is fine, that's just the cosmetics rubber no cords or belts were touched
BIG cam ...... 305 45 18 Mickys ...... BMR suspensions
davidscamaro is offline   Reply With Quote
Old 07-30-2021, 10:22 PM   #6
Wizard1183
Wizard1183's Avatar
Drives: ABM SS2/RS M6
Send a message via Yahoo to Wizard1183
You ****ed up when you went to long dong silvers. That place services nothing but frozen fish sticks. Shitty seafood joint. I wouldn’t waste my time going there. WSPECIALLY if the drive through is a damn auto cross track lol
Life is short, drive it like you stole it!
Wizard1183 is offline   Reply With Quote
Old 07-30-2021, 10:25 PM   #7
Car Nation Videos
YouTube-Car Nation Videos
Car Nation Videos's Avatar
Drives: 2010 Chevrolet Camaro
Bro, take a razor or a knife and cut that rubber piece off. Then take some spray paint and touch that rim up. Just sand it down a little and use painters tape, to tape it off and then just touch it up.
The tire is fine!
Car Nation Videos is offline   Reply With Quote
Old 07-30-2021, 10:27 PM   #8
Car Nation Videos
I can fix that in literally about 10 minutes.
Old 07-31-2021, 07:10 AM   #9
HawkeyeZL1
HawkeyeZL1's Avatar
Drives: 2012 ZL1 #1156, 2003 Silverado SS
Super glue the tire. I did it and you can't tell. Just touch up the wheel till it's time for new tires and then upgrade or get it fixed right.
2012 ZL1 #1156, born 5/8/2012. Rotofab cold air intake, Elite Engineering catch can, Texas Speed Long tube headers with off road connections and of course a tune by DynoSteve.
HawkeyeZL1 is offline   Reply With Quote
Old 07-31-2021, 07:13 AM   #10
redcoats1976
thats a minor bump in the road.a 4 door camaro would make me cry...
Old 07-31-2021, 08:32 AM   #11
Nailbender
Nailbender's Avatar
Drives: Chevy Camaro hwse 2018 GMC Sierra 1
I have the same rims I would be upset to,luckily it does look like a reasonable fix good luck.
Nailbender is offline   Reply With Quote
Old 07-31-2021, 09:20 AM   #12
Rob3D
Rob3D's Avatar
Drives: Car
Doesn’t make me cry. I know how to drive.
Rob3D is offline   Reply With Quote
Old 07-31-2021, 10:50 AM   #13
wasthatacop?
wasthatacop?'s Avatar
Drives: 2010 2SS
The tire is fine!
Agreed
2010 2SS living in Los Angeles
replaced engine @ 93,000 miles w/ crate engine, camshaft by Comp Cams installed by me, replaced valve train parts,
1.4" BMR lowering springs
ZL1 factory rims
misc: drilled and slotted rotors, fresh air brake cooling system, new speakers, installed reverse camera, muffler delete
wasthatacop? is offline   Reply With Quote
Old 07-31-2021, 06:41 PM   #14
theflea42
#938 of 1524
I cut that piece of rubber off and touched up the rim. The red doesn't quite match, but it's better than it was.
