Old 07-31-2021, 04:51 AM   #1
aaberg
30th conv & 45th 2SS conv
aaberg's Avatar
Drives: 1997 30th conv & 2012 45th conv
How do I check fuel pump and pressure?
I think my fuel pump doesn't work. How do I check fuel pump and pressure on A Camaro 2012 SS?
aaberg is offline   Reply With Quote
Old 07-31-2021, 06:26 AM   #2
aaberg
aaberg's Avatar
Update: I have pulled this info with OBD tool:
Fuel pressure: 310 kPa (45 psi)
Fuel pump Commanded state 52 % (then I increase to about 60 it drops back to about 50 - doesn't know meaning of that).
If I have understand the service manual correct the fuel line pressure should increase to greater than 410 kPa (60 psi)
Old 07-31-2021, 07:07 AM   #3
morepowerjoe
morepowerjoe's Avatar
Drives: 2012 Chevrolet Camaro l99
Yeah I think that is a little low. Mine at idle is right at 58 psi.
DSS Pistons, Eagle ESP L19 Rods, ARP Head and Main Studs, TSP PRC CNC Ported Heads milled .030, Cometic .040 Head Gaskets, GPI SS3 VVT Camshaft, GM Racing Lifters, CHE Trunnions, Melling 10355HV Oil Pump, Cold Air Inductions CAI, Fast LSXR Intake Manifold, Nick Williams 103 TB, TSP Longtubes, ZL1 Fuel Pump, Mishimoto Radiator and Oil Cooler, 3600 Circle D Converter, Tru Cool 40k Tranny Cooler, Fluid Dynamics Balancer, EBC 3GD Rotors with EBC Bluestuff NDX Pads, Bilstein B6 Shocks / Struts with Eibach ZL1 Drop Springs
Build Thread https://www.camaro5.com/forums/showthread.php?t=609817
morepowerjoe is offline   Reply With Quote
Old 07-31-2021, 08:43 AM   #4
hunter1660
hunter1660's Avatar
Drives: 2011ss/rs camaro
Shrader valve on fuel rail
. OBX LTH,Rotofab,Magnuson Heartbeat.AEM wideband, HP Tuners
hunter1660 is offline   Reply With Quote
Old 07-31-2021, 09:11 AM   #5
gunchamp
gunchamp's Avatar
Drives: 15 Camaro SS
Yup. Screw a mechanical fuel gauge on there and start her up
15 Camaro SS- GPI max top end, ESS Vortech V3 9psi, ID 1050s, ZL1 pump, JMS bap, Long tubes, Corsa extreme, Circle D pro 5C, 391 rear, DSS carbon drive shaft, poly cradle bushings, tuned by Ted Jannetty and much much more
gunchamp is offline   Reply With Quote
Old 07-31-2021, 01:41 PM   #6
aaberg
aaberg's Avatar
Yes, I will buy a mechanical fuel gauge!
Video from latest start: https://youtu.be/j9eKtrIbaTo
I have used STP injector cleaner and and added another 3 gallon gas today. Think the car runs a bit better after running engine (not driving) for about 15 minutes.
As the OBD-reading shows it's also up to 400 kPa/58 psi. Can it be there is dirt and water in the lines? During engine restoration the car have stand still in garage for 1,5 years. But still no idle below 600 rpm.
fuel pressure, fuel pump
