![]() Drives: 2012 SS L99 Converible Join Date: Mar 2016
12 l99 tuning question
So I did the DOD delete and upgraded the cam to a Tooley stage 2 along with associated parts plus a 3,200 stall converter. I had it dyno tuned at Hartsel Perforfmance in Tiffin, Ohio. He said he had an issue with the adaptive idle and had to shut it off. Once you’d go over 1.5mph it would kick the idle up to the point it felt like it would go 20mph all on its own. Anyone run into this? Other than that, it seems to run pretty well
2012 L99 Convertible SS
Tooley Racing Stage 2 DOD delete, 3,200 stall converter, Shorty headers and custom stainless exhaust, CAI, and tune as mods |
![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2012 Chevrolet Camaro l99 Join Date: Aug 2020
I hate to say it but I think you need a new tuner.
DSS Pistons, Eagle ESP L19 Rods, ARP Head and Main Studs, TSP PRC CNC Ported Heads milled .030, Cometic .040 Head Gaskets, GPI SS3 VVT Camshaft, GM Racing Lifters, CHE Trunnions, Melling 10355HV Oil Pump, Cold Air Inductions CAI, Fast LSXR Intake Manifold, Nick Williams 103 TB, TSP Longtubes, ZL1 Fuel Pump, Mishimoto Radiator and Oil Cooler, 3600 Circle D Converter, Tru Cool 40k Tranny Cooler, Fluid Dynamics Balancer, EBC 3GD Rotors with EBC Bluestuff NDX Pads, Bilstein B6 Shocks / Struts with Eibach ZL1 Drop Springs
Build Thread https://www.camaro5.com/forums/showthread.php?t=609817 |
![]() ![]() ![]() ![]() Drives: 2011ss/rs camaro Join Date: Sep 2011
I second the notion
![]() ![]() ![]() ![]() Drives: 2012 Camaro SS Join Date: Dec 2019
Contact dyno Steve above ^^ he might be able to tune it for you. He has done several tunes for me and they are all amazing
2012 Camaro 2SS/RS - CSP Custom Cam 232/240 .615/.615 113 +3, Texas speed CNC heads, FTI billet triple disc converter, K&N cai, Katech ported TB, GPI Ported/rod modded manifold, Texas speed 1 7/8 headers, HFC, Flowmaster 2 chambers with x pipe, Mishimoto CC, MSD wires, Roto fab washer relocation, tru cool 40k trans cooler, apex scoop, Pedders extreme coil overs and much more!!
8.60 @ 157 @ 4200lbs
Tune
Do you have access to hp tuners ? Post a log and your file best way for help. But yes its in the tune that needs fixed.
2010 camaro twin turbo 8.60 @ 157 full weight 4200
#6 | |
He said he loaded a base tune when all the work was performed since he didn’t know where the previous tune was at. Then while on the dyno he tweaked things from there. Said he didn’t notice the idle issue until he went to test drive it. I had an aftermarket ported throttle body he didn’t like so I bought a new factory one. He also found a small dead spot in the old gas pedal so I replaced that as well with a new one.
#7 |
This is the same car I had issues with when I bought the box tune where you emailed me a file that had a tune on it. You are several hours away but might be able to make the trek depending how busy you are.
Tooley Racing Stage 2 DOD delete, 3,200 stall converter, Shorty headers and custom stainless exhaust, CAI, and tune as mods Last edited by Ponchonutty; 08-08-2021 at 11:55 PM. |
#8 |
After doing some digging between my tuner and such it appears the calibration ID in my car is attached to a manual car, not an auto. To rule out anything else I’m going to see if I can get a GM dealer to load the correct file and start over again.
#9 |
GPI Sales Consultant
This sounds like min. airflow issues - needs more/proper tuning. That's a pretty mild camshaft and should be pretty transparent at anything over fast idle speeds.
Got a question about a GPI product? Feel free to shoot me a message! |
#10 |
Well the adaptive idle is separate from running down the road.
#11 | |
When set right, it should give you nice smooth transitions on and off the accelerator, but none of that cruise control effect. Some times in 1st gear you can use a little bit of that effect to help with parking lot bucking in stick cars, but then you risk flaring whenever you go to the clutch.
#12 | |
Going to GM dealer Monday to put all back to stock as far as the tune is concerned. My tuner is going to meet me there to get it so we can get it back to his shop then mess with the tune from there.
#13 | |
As you noted, the adaptive idle for the the airflow side will not pull the throttle body closed when the vehicle speed is over the threshold, and the adaptive idle spark only has so much authority. That's why, when you come to a stop, the adaptive idle criteria for vehicle speed is met, and the idle speed drops to where it should be.
#14 | |
