Old 07-31-2021, 06:36 PM   #1
Skyler1955
Skyler1955's Avatar
Drives: 2011 Camaro 2ss /1956 chevy Bel Air
1/2 to WOT Problems (medium and high load)
Hi everyone I have a 2011 Camaro SS2, when I first start the car and drive no problems at any load or RPM. when the car warms up and I give it more than 1/2 throttle it frequently bogs/misfires like it cutting fuel and when you let off the throttle it will backfire sometimes. it just randomly starting doing this. there are no codes. I need some help and opinions.
More about the car
- LS3
- BTR Stage 4 cam Spec. 233/250 .618"/.596" 113+5
- Cold Air intake
- Long tube headers with high flow cats
- Straight pipe
- M6, final drive 4.10
- Tuned by PCM of NC
- tuned on air density (NOT MAF)
Things I checked & replace
- Checked spark plugs, all were good but cylinder number 2 looked like it had a leaky fuel injected.
- Replace fuel injector for cylinder #2 did not fix problem
- Replace spark plug wire did not fix problem
HP tune and log files
- File: https://drive.google.com/file/d/1rIp...ew?usp=sharing
- Log: https://drive.google.com/file/d/1nS_...ew?usp=sharing
(LOG of times when events were happening)
- 5:36 bog/maybe misfire
- 5:47-5:50 bog/maybe misfire
- 5:54 bog maybe misfire
- 5:56 closed loop commanded off
- 6:03 closed loop commanded on
- 6:06 closed loop commanded off
- 6:09 bog/maybe misfire
I NEED SOME HELP AND ADVICE!
Skyler1955 is offline   Reply With Quote
Old 08-01-2021, 12:49 AM   #2
Mouse330
Mouse330's Avatar
Drives: 2011 2SS, 2006 GMC Sierra
Remove the MAF and visually look at the hot wires to see if there’s anything on them. Spray them with brake cleaner or air intake cleaner, blow them off or let dry. Reinstall and test drive
Mouse330 is offline   Reply With Quote
Old 08-01-2021, 01:14 PM   #3
Skyler1955
Skyler1955's Avatar
I have check the MAF sensor look good and clean. had a replacement one went ahead and changed it still no difference
Old 08-01-2021, 09:18 PM   #4
Car Nation Videos
YouTube-Car Nation Videos
Car Nation Videos's Avatar
Drives: 2010 Chevrolet Camaro
MAF, Coil Packs, Spark Plugs.
Easy Fix
Car Nation Videos is offline   Reply With Quote
Old 08-07-2021, 05:13 PM   #5
mrWizard
mrWizard's Avatar
Drives: 2010 Camaro 2SS/RS M6
Did you every get anywhere with this?
I'm having misfires in cylinder 1 under WOT, no codes. Swapped plugs, wires, and coils and still happening. Haven't checked harnesses or injectors yet. I also checked loose hoses and cleaned the MAF and it's connector.
mrWizard is offline   Reply With Quote
Old 08-23-2021, 09:50 AM   #6
mrWizard
mrWizard's Avatar
Spark plugs and wires.
Most likely was my wires. I skimped on replacing them a while back. After replacing them and plugs, everything is normal.
Old 08-25-2021, 12:38 AM   #7
wasthatacop?
wasthatacop?'s Avatar
Drives: 2010 2SS
Did you fix it?
2010 2SS living in Los Angeles
replaced engine @ 93,000 miles w/ crate engine, camshaft by Comp Cams installed by me, replaced valve train parts,
1.4" BMR lowering springs
ZL1 factory rims
misc: drilled and slotted rotors, fresh air brake cooling system, new speakers, installed reverse camera, muffler delete
wasthatacop? is offline   Reply With Quote
Old 09-29-2021, 11:14 PM   #8
Skyler1955
Skyler1955's Avatar
Hi sorry for the delay but I did fix it, coil number 4 started to have a weak spark when it got hot and under load. Changed it and the problem went away thanks for the help
bog, help needed, miss-fire, under load
