Old 08-03-2021, 12:27 PM   #1
zz430camaro
zz430camaro's Avatar
Drives: 2015 1LE
Street Supercharger
Which do you think is the best type of supercharger for a street car? Centrifugal (ProCharger) or Screw (Whipple)?
2015 1LE, TSP 225/236 113+3, VMAX Throttle Body, CAI with race scoop, GPI Ported Intake, Land Speed Stage 2 Heads, 1-7/8 headers, NPP exhaust, 25% Fluidampr, LT1-S Monster Clutch, 485 RWHP & 444 TQ
zz430camaro is offline   Reply With Quote
Old 08-03-2021, 01:11 PM   #2
RupertPupkin
Drives: 2014 Camaro SS 1Le
All are considered street friendly… I’m biased towards a centri setup.
2014 SS 1LE Money Pit/ Forged 402
CAM 22X/24X, .619/.617, 113 LSA/ LS9 Heads
FIC 1200cc/DSX Aux Pump//McLeod RXT Clutch
730whp: 630Trq
RupertPupkin is offline   Reply With Quote
Old 08-03-2021, 02:58 PM   #3
bayarea408
bayarea408's Avatar
Drives: T
centri, its just simpler plug and play. Then when you do things like add meth or run spray its easier to set that up too. If i didnt have my single turbo kit i'd probably get an ECS kit.
bayarea408 is offline   Reply With Quote
Old 08-03-2021, 03:46 PM   #4
fz4k98
Drives: 2013 1ss
30k + on my whipple and if the tune is good you dont even know its there unless you get on it.
appears to be solid as i have bounced it off the rev limiter several times with no issues. As for maintenance, plugs at 20k and belt at 28k.
The torque is great from 2k rpm up.
fz4k98 is offline   Reply With Quote
Old 08-03-2021, 04:28 PM   #5
Bigdumogre
Bigdumogre's Avatar
Drives: 2012 Camaro SS
They all work great for daily but I would go screw type. There is a reason why car companies add them to factory builds.
2012 Camaro 2SS/RS - CSP Custom Cam 232/240 .615/.615 113 +3, Texas speed CNC heads, FTI billet triple disc converter, K&N cai, Katech ported TB, GPI Ported/rod modded manifold, Texas speed 1 7/8 headers, HFC, Flowmaster 2 chambers with x pipe, Mishimoto CC, MSD wires, Roto fab washer relocation, tru cool 40k trans cooler, apex scoop, Pedders extreme coil overs and much more!!
Bigdumogre is offline   Reply With Quote
Old 08-03-2021, 08:03 PM   #6
RupertPupkin
There’s a reason for turbos also.
730whp: 630Trq
Old 08-04-2021, 12:08 PM   #7
RockSVT
Drives: 2010 Camaro SS
I would say it depends on your goals. Sub 700-750whp a screw blower is pretty hard to beat. Once your goals are 800whp+ I think you're better off with either a Centrifugal or a Turbo setup.
RockSVT is offline   Reply With Quote
Old 08-04-2021, 01:15 PM   #8
sscamaro
Drives: 2010 2SS, 2017 Silverado LTZ
Screw superchargers give instant torq. Which I think is better for the street.
sscamaro is offline   Reply With Quote
Old 08-05-2021, 08:01 AM   #9
CamaroCracka
CamaroCracka's Avatar
Drives: 2010 Turbo LS3
Instant torque is hard to put to the ground on the street, but they do very well at the track.
Old 08-05-2021, 09:21 AM   #10
fz4k98
Drives: 2013 1ss
I was having trouble with this until i switched to adjustable rear shocks. What a difference. i can dial in anywhere from 1st gear acting like in a rains storm and having to pedal to full hookup.
Old 08-05-2021, 10:22 AM   #11
JANNETTYRACING
JANNETTYRACING's Avatar
There will always be a debate and people will defend what they have.
Totally unbiased professional opinion, Whipple or Magnuson supercharger is best suited for set it and forget it bolt on power.
A lower HP PD blower will feel faster than a higher powered Centri, due to Boost Curves.
So from the drivers seat driving back to back SC Gen 5 camaros, the PD will always be more impressive.
Ted.
www.jannettyracing.com
Celebrating 39 years Performance parts, Installation, Fabrication, Dyno tuning, Remote custom tuning, and alignments. 203-753-7223 Waterbury CT. 06705
email tedj@jannettyracing.com
Old 08-09-2021, 12:22 PM   #12
SSyclone
SSyclone's Avatar
Drives: 2011 2SS Inferno Orange
Id start by scouring the classifieds here. Keep an open mind and be ready when something you like pops up. These guys change their setups like their underwear.
Whatever you wind up with, when you upgrade Injector size and pump capacity go big enough to do flex fuel. You'll be able to run 93 or e85 and make safer power. With a good tune of course.
2011 Camaro SS
Buckets of money under hood!
SSyclone is offline   Reply With Quote
Old 08-13-2021, 04:07 PM   #13
RealQuick
Drives: 2010 Camaro 2SS M6 - Intake/Exhaust
Centrifugal superchargers are probably the easiest to manage on the street from a traction perspective as boost is linear.
RealQuick is offline   Reply With Quote
Old 08-14-2021, 05:48 PM   #14
Little Walter
Drives: ZL1
We have several around here with PD Blowers and Pro Chargers, a couple from Hutter Performance equally matched with both PD and Centri blowers, I agree with you 100% without a doubt on a small tire car on the street the Pro charged cars hook better due to the torque curve every time and really bring it on the big end.
Little Walter is offline   Reply With Quote
