08-07-2021, 02:08 PM | #1 |
Drives: 1997 30th conv & 2012 45th conv Join Date: Jul 2017
Daytime running light not working Camaro 2012 SS
So I have had my front reinstalled and now my daytime running light in front doesn't work. Both left and right is off. So far I have checked:
1. Connection on right side (except for daylight all lamps works fine). 2. Checked fuse 50 in engine fuse box (not burned). 3. Checked both lamps (OK). 4. Pulled these error codes: |
08-07-2021, 05:08 PM | #2 |
Drives: 2010 Camaro 2SSRS M6 Join Date: Jan 2019
Sounds like you may have chafed/broken a wire possibly causing a high resistance in the circuit.
ECS supercharger, custom ground cam, ported throttle body, long tube headers, aeromotive fuel pump, fic injectors, ATI super damper, Corsa Extreme exhaust, elite engineering catch can and many other things.
08-07-2021, 08:43 PM | #3 |
Drives: 2012 Camaro SS Join Date: Dec 2019
So it happened after you reinstalled front bumper? Check all connections and wires within that area.
2012 Camaro 2SS/RS - CSP Custom Cam 232/240 .615/.615 113 +3, Texas speed CNC heads, FTI billet triple disc converter, K&N cai, Katech ported TB, GPI Ported/rod modded manifold, Texas speed 1 7/8 headers, HFC, Flowmaster 2 chambers with x pipe, Mishimoto CC, MSD wires, Roto fab washer relocation, tru cool 40k trans cooler, apex scoop, Pedders extreme coil overs and much more!!
08-08-2021, 04:55 AM | #4 |
Only connection I know is on right side uper from daytime light. Or have I missed any connection?
