Old 08-07-2021, 10:06 PM   #1
Mlgprodriver
Drives: 2010 Camaro 2SS RS
First start up after Cam! HELP
Okay just finished basically rebuilding my whole valve train and doing a bunch of other small and big things after a valve spring broke. Ended up doing an endless amount of things.
Can anyone tell me if my car sounds right? What will the lifter tap or valve tap sound like if I have it? I just want to make sure everything is healthy. AND HOW CAN I QUIET THIS THING DOWN? I have 2 mufflers and resonators the long tube headers may just be to much for me. Thinking about going back with the original manifolds! Please help guys I hope the car is running healthy my check engine light isn’t blinking so I think I’m good!
https://m.youtube.com/shorts/xEWI3dQPKzo?feature=share
Mlgprodriver is offline   Reply With Quote
Old 08-07-2021, 10:10 PM   #2
Mlgprodriver
Also another video any help much appreciated!
https://youtu.be/gR-QX2mhlfQ
Old 08-07-2021, 11:08 PM   #3
Aqua Blue RS/SS
Aqua Blue RS/SS's Avatar
Drives: ABM #93
Sounds pretty nice to me. Lifter tap will sound almost like a metallic knock or tap from the top end of the engine that will increase and decrease with speed. If it is there you will notice it I promise. Stock manifolds are gonna neuter that cam swap. I would shop around for some quiet high flow mufflers.
ABM #2399 2SS/RS:SOLD
ABM #93 2SS/RS Black Rally stripes, Titanium Interior 4,000 miles: GM GFX side skirts and diffuser waiting on paint, GM dovetail, GM heritage, RPI ZL1 style splitter.
‘87 IROC-Z Iroc blue. all original unmolested with 50K miles.
Aqua Blue RS/SS is offline   Reply With Quote
Old 08-08-2021, 12:34 AM   #4
InFiD3ViL
InFiD3ViL's Avatar
All I heard was perfection
Old 08-08-2021, 03:01 AM   #5
moezer
Drives: Camaro ss
Don’t u need to tune the car after a cam swap?
To lower its volume then put some high flow mufflers that said
moezer is offline   Reply With Quote
Old 08-08-2021, 03:07 AM   #6
morepowerjoe
morepowerjoe's Avatar
Drives: 2012 Chevrolet Camaro l99
Yes it won't run without a tune. It sounds good to me. Yeah you'll be going totally backwards with stock manifolds.
DSS Pistons, Eagle ESP L19 Rods, ARP Head and Main Studs, TSP PRC CNC Ported Heads milled .030, Cometic .040 Head Gaskets, GPI SS3 VVT Camshaft, GM Racing Lifters, CHE Trunnions, Melling 10355HV Oil Pump, Cold Air Inductions CAI, Fast LSXR Intake Manifold, Nick Williams 103 TB, TSP Longtubes, ZL1 Fuel Pump, Mishimoto Radiator and Oil Cooler, 3600 Circle D Converter, Tru Cool 40k Tranny Cooler, Fluid Dynamics Balancer, EBC 3GD Rotors with EBC Bluestuff NDX Pads, Bilstein B6 Shocks / Struts with Eibach ZL1 Drop Springs
Build Thread https://www.camaro5.com/forums/showthread.php?t=609817
morepowerjoe is offline   Reply With Quote
Old 08-08-2021, 07:45 AM   #7
Car Nation Videos
YouTube-Car Nation Videos
Car Nation Videos's Avatar
Drives: 2010 Chevrolet Camaro
Sounds like a stage 3 cam to me.
Car Nation Videos is offline   Reply With Quote
Old 08-08-2021, 10:28 AM   #8
frankwjr
frankwjr's Avatar
Drives: 2010 SS 2SS M6
send it...
Old 08-08-2021, 11:50 AM   #9
aaberg
30th conv & 45th 2SS conv
aaberg's Avatar
Drives: 1997 30th conv & 2012 45th conv
Sounds OK to mee. I have restored a L99-engine and was confused there was more ticking noise than I expected but everyone says it's OK. Added a video for to compare with from my engine: https://youtu.be/WgK9ID66zrQ
aaberg is offline   Reply With Quote
Old 08-08-2021, 02:33 PM   #10
Mlgprodriver
Okay now on to engine codes...
P0122
Raw code: 0122
ECU: Engine control unit[Archive (inactive)]
Status: Permanent
OBDII: Throttle position (TP) switch A/accelerator pedal position (APP) switch A - low input
Throttle Position (TP) Sensor Circuit Low Input
============2==============
P0443
Raw code: 0443
Status: Permanent
OBDII: Evaporative emission (EVAP) canister purge valve - circuit malfunction
Evaporative Emission (EVAP) Canister Purge Valve Circuit Malfunction
============3==============
P0107
Raw code: 0107
Status: Permanent
OBDII: Manifold absolute pressure (MAP) sensor/barometric pressure (BARO) sensor - low input
Manifold Absolute Pressure (MAP) Sensor Circuit Low Voltage
============4==============
P0300
Raw code: 0300
Status: Permanent
OBDII: Random/multiple cylinder(s) - misfire detected
Random Misfire
Getting those codes along with about 8 oxygen sensor codes. Oxygen sensor codes are explainable with the headers. Any idea on those codes? Thanks!
Old 08-08-2021, 02:48 PM   #11
morepowerjoe
Please tell me you did a tune on the engine after you did the cam swap?
Old 08-08-2021, 04:10 PM   #12
Car Nation Videos
That should have all been taken care of in the tune once the cam was installed.
Old 08-08-2021, 04:43 PM   #13
morepowerjoe
But he never said weather or not he did a tune and by whom.
Old 08-08-2021, 04:51 PM   #14
Mlgprodriver
No we do not have it tuned as of yet. My shop explain to me I could do the work and have it brought in on my trailer to them. He explained it would be okay to start it, but very dangerous to drive it. Is this terrible? Should I have never started it?
